Inroads table editor
Inroads SS4: 08.11.09.789
Where did the Geometry > Vertical Curve Set > Table Editor go to in the Inroads box?
Or where can i find it in Open Roads Technology?
Jean Castro
  • It is still available.  Does your menu look differently than the one pictured below?
  • Hi Jacquelyn Pettus
    Below is a screenshot of mine, and yes it is different. The Table Editor is missing !?? Is there a key-in to access the Table Editor?
    I also want to refer to my older posts about 'wrong icons under correct tooltips in Inroads' in this forum.
    Seems that i'am having problems with 'Inroads' (and only Inroads) on my machine, despite all the solutions and tips & trics I've done:
    • toolbars > reset (all and individual);
    • uninstall > registry cleanup > re-install
    • new harddrive (SSD)
    • format c:\ > and change of OS to windows 8.1 and installation of Inroads SS4 (latest version)
    • update graphic drivers
    • etc.
    None of this seems to help to get the installation of Inroads right. Could it be computer specific? (I starting to think that i have a workstation that is build on a Monday :))
    Computer = HP workstation Z400 with Xeon W3565 @ 3.2 GHz, 24 MB Ram; Nividia Quadro 4000 on driver 341.21;
    All suggestions to fix the problem are welcome.
    Jean Castro
Reply
    • etc.
    Jean Castro
