Hello Community.
I have a complex corridor with several Corridors Objects.I need to change horizontal alignment linked to that coriidor. Using an alternative horizontal alignment. Is this possible? Or I have to repeat again the corridor with all conditioning factors. (Parametric Constrains, Point Controls, End condition exceptions....)
Thanks.
Unknown said:We logged that as a Customer Request long time ago. This is very common in engineering workflows.
Unknown said:I hope you guys at Bentley read this forum and can see what users need.
In the context of OpenRoads, there is a field in the Corridor Objects on the Template Drop tab for "Horizontal Name" which holds the alignment name. It's greyed out, but if it wasn't, that could be one way to modify the alignment. This would be absolutely lovely. With all the other things that can be changed fluidly, this seems like just one small step toward perfection.
