Update previously Imported Geometry from gpk
I have used the Import Geometry feature to import several horizontal alignments from the project's gpk file in order to create superelevation sections.  Which is working fine, however, some of these alignment have been redefined in the gpk and the changes are not reflected in the previously imported geometry.  This has resulted in busted models and cross sections.
My question is this: is there a way to update the alignments created through the Import Geometry tool so I don't have to scrap the superelevation design that we have in place?  I haven't been able to locate a "refresh" linear elements/geometry function anywhere.
Thanks in advance
