how to parametric "Trim To Intersection"
Just a quick question: I'm make a (first time) parametric design of a road.
 With Civil Tools > Horizontal Geometry I can make lines connect by using simple arc's.
But I can't find a parametric sollution to the command "Trim To Intersection"
What have I overlooked?
(Powercivil SS4)
Parents Reply
  • I'm positive I have used rules to create this and other lines. But now I can't use (A7) (partial) offset anymore. This line has arc's and other partial offset's already in the drawing. This line is part of the desing where the other "problems" occur. When making new lines to reproduce, everything happens the way I want it to work. So for this project I go the DWG route to get rid of all rules. But that's not the ay I want to go. Any suggestions?
