Profiles in SS4 and Snapping
AccuSnap needs to work inside the profile view. If Accusnap is on then the profile tools should properly lock in on elements, not lock the float around and require the user to lock inthe pop up window.  If you need to add a lock somewhere to make the inputs respect AccuSnap then fine but currently manual drawing anything in a profile window is more tedious than it needs to be. We should also be able to draw a line string and not have to draw independent line segments. Lastly open roads needs to support the legacy Inroads shortcuts and using keyin text files.
