Clipping Volumes and DCDrape - Openroads
I am having several issues with DCDrape.pal
First, the terrain elements in Openroads do not appear to support materials being attached. The dialog will attach and the query will find the DCDrape material but they do not show up in the element properties dialog. I can bring in the legacy surfaces .TIN or .DTM and add materials there but this is less that desirable.
Once I attach aerials and switch view to smooth every thing works fine ( with the legacy surfaces) but if I try to apply a view clipping volume the drape function no longer works. Is this simply "how it works"? are others able to duplicate these errors. It there a plan to fix these issue...
Any comments or suggestion are appreciated,
Terry
Microstation 08.11.09.655 | Geopak 08.11.09.789 | Inroads 08.11.09.789
