Hi
I want to "change" the linear template end condition applied to some of the standard civil cells. I am able to edit the template, but want to know if i can change the entire template i.e. change from with to without sidewalk? I would like to do this so i don't have to recreate a cell library with all the possible combinations.
I would also like to change the radii of the curves on the T junctions after placing the civil cells, again so i don't have to recreate the library. Is this possible? If so please point me in the right direction.
version No. 08.11.09.789
David
As for changing the radii after the cell is placed, I thought all dimensions of elements formed in a civil cell should have civil rule handles so that you can manipulate those elements. If you had an ordinary Microstation element floating out there, if you select it, does it have handles? If it does have handles that you can manipulate with your current settings, then there might be an issue with the way the civil cell was created. If any given Microstation element doesn't have handles after you select it with the selection tool, you'll need to use the switch that's included in the selection tool settings. Changing this may fix your problem. HTH
P.S. I just realized that since you haven't commented on any other civil elements not having any handles, perhaps I'm on the wrong track to helping you here.
Thanks DerekThe handles weren't showing up but i was able to edit the elements from the element information dialog box so that is sorted now.But your idea triggered something, i figured it out. I needed to open project explorer then go to the civil cell, once i had the template drop selected i was able to edit it under the element information box.
Hope that helps someone else in the future.
Regards David Marx
Answer Verified By: David Marx
Michael Barkasi
Application Engineer
Reality Modeling
