Show Pipe Flow Direction Arrows on Cross-Sections
In InRoads Drainage, is there a way to generate pipe flow direction arrows for cross sections?  I am looking for a result similar to the flow direction arrows you can generate for plan view using the command Drainage > View > Flow Direction Arrows.  I need arrows for both crossing features and projected features of the storm and sanitary database, (crossing features would show up or down arrows).
If this is not possible, I'm looking for a work around that is faster than manual entry.
