Hi everyone,
Because the line I try to model is a little complex, so there are more than 100 different corridors generated in this line.
When I calculate superelevation I need to pick all the corridors one by one, sometimes that's easily to cause mistake after I assign the superelevation to those corridors. How should I merge the individual corridors together as there is only one corridor template along this road?
Koalar
If you're ok with having separate corridors and your goal here is simply to have one unified terrain model, you can do that. Either create a terrain model from each corridor and blend them all together as one complex terrain, or else there's a couple other ways to create one single non-complex terrain, among them using a graphical filter. See communities.bentley.com/.../14435.video-create-terrain-using-graphical-filter
Answer Verified By: Koalar Q
