MX Drainage MicroStation Solids Problem
Hi All,
With reference to the link provided, has anyone had problems bringing the MX Drainage network into the draw display when the pipe has a radius applied to it? I can successfully send the network into the draw display when there is no radius applied to the pipes using the process contained within the link below.
communities.bentley.com/.../how-to-bring-mx-drainage-data-into-bentley-navigator
Ross
