MX V8i SS4 - Calculating Earthworks
Dear OpenRoads Experts,
Is there a way to prompt OpenRoads to calculate earthworks as shows on the sketches below? I was examining many possible settings in End Area Volume tool and can't get my head around it. In InRoads SS2 it was easily achievable by defining unsuitable materials by feature. I thought I can get the similar result using Surface Template in SS4 but not. I would be very grateful for any help.
Krzysztof
  • Hi Krzysztof
    I am looking at this but at the moment I don't have a solution. Its likely to be something that linemode can do, but I haven't got it yet. Please bear with me.
    Simon Pegg B.Eng (Hons) I.Eng
    Bentley Product Advantage Group
    Civil Support Manager
    B E N T L E Y S Y S T E M S
    BE Productive BE Involved BE Smart
    For Support Please Try BE Communities :
    communities.bentley.com/.../default.aspx
    Click Here to Visit my MX Blog
  • I am having a similar issue. Was a solution for this every found?
  • workaround would be to use unsuitable material by station - will work only if you have a single material to be clasified as unsuitable in a single cross-section. so it is not really a workaround.
    you can try to model unsuitable materials same way as proposed components - that is very timeconsuming and possible only in simple scenarios.
    and you can try to use surface template and classify its componets as MDC. I haven't tested that in depth. You will not get correct cut/fill hatching on your cross-sections this way but with a helkp of Excel you can get volumes of fill and cut. As I said, not tested that in depth, but when reporting Cut should be fine and to fill you will need to add MDC unclassified.
    I really need someone from Bentley to say sth here. This is a very basic engineering need. In most project I ve been involved since I started to work as designer I had more than one material to be removed in single station - topsoi of variuos depth, demolitions, etc.
    Best,
    Adam
    OpenRoads Designer 2022 (10.12)  |  OpenRail Designer 2022 (10.12)
  • I have tested the MDC and couldn't get it to work for the existing pavement.  This picture show what we need to be able to calculate.  The right part of existing pavement is calculated as pavement removal/rock but that is it.  Then the left side needs to be calculated as pavement removal/rock and then be filled back in for the proposed condition.
  • Your sketch shows what we need. I was expecting that you can classify surface template as MDC. Apparently it will not work. In my cases next to the existing pavement to be removed we have topsoil to be stripped. It would be great if we could clasify surface templates as unsuitable material. Then cut volume would be reduced by unsuitable material and fill would be increased to refill demolishes or topsoil stripping.
    Any one at Bentley have any idea how we can calculate End Area Volumes with SS4?
    It looks that users who decided to move to OpenRoads Technology would be trapped at the very end - at the stage wher they need to provbide Client with bill of quantities.
    If there is no workaround, than it would be fair to warn your users.
    Best,
    Adam
  • Wesley,
    Does the link work for you? appsnet.bentley.com/.../addcall.aspx
    If not, you need to go to bentley.com > SELECTServices > Service Request Manager > Product Support.
    Hope this helps.
    Krzysztof
Reply Children
