InRoads S&S Curved Pipe Elevations
When placing curved pipes in sanitary sewer, I am able to assign an invert in and an invert out with a given radius.  However, when the graphic is drawn on the screen, it is drawing the pipe with elevations at the “in”, “out”, and “midpoint” as the average of the entered invert values.  The pipe is also showing up on the cross sections at the average elevation and not the elevations it should be at that given cross section.  I did an edit/review of the pipe and confirmed that the inverts I entered were still as I intended them to be.  What is the fix for this?
