InRoads Surface Edits with Modeler
I am editing the surface manually instead of using a ton of end condition overrides in Roadway Designer. Once I have done the edits to the surface, will I be able to use the Model at all? Will the model override all my changes that I did manually to the surface features? If so, is there any way to avoid this?
Thank You!
