PowerGEOPAK V8i SS3 Version 08.11.09.722
When I have a group of chains selected in the Survey Details Element List organized in descending order and I export them to .xml the order of the chains is not maintained in the resulting .xml. Instead they are re-organized into ascending order. How can I make the control the export to result in descending order consistent with the organization of the Element List?
<LandXML version="1.2" date="7/8/2015" time="1:42:41PM"> <Project name="Field Book 1" /> <Units> <Imperial linearUnit="foot" areaUnit="squareFoot" volumeUnit="cubicYard" angularUnit="radians" /> </Units> <Application name="Survey" manufacturer="Bentley Systems Inc." version="1.0" manufacturerURL="www.bentley.com" /> <Survey desc="NetDesc"> <SurveyHeader name="14C0012-150416.TXT" desc="NetDesc" /> </Survey> <Survey desc="NetDesc"> <SurveyHeader name="JN119808_ControlPts_7-2014.txt.txt" desc="NetDesc" /> </Survey> <Survey desc="NetDesc"> <SurveyHeader name="14C0012-150422.txt" desc="NetDesc" /> </Survey> <CgPoints> <CgPoint name="20142" code="XYZ" desc="" pointGeometry="point" DTMAttribute="determinebyfeature" pntSurv="" zoneNumber="5">802743.863 19663056.789 611.499</CgPoint> <CgPoint name="20143" code="XYZ" desc="" pointGeometry="point" DTMAttribute="determinebyfeature" pntSurv="" zoneNumber="7">802742.276 19663035.883 609.598</CgPoint> <CgPoint name="20144" code="XYZ" desc="" pointGeometry="point" DTMAttribute="determinebyfeature" pntSurv="" zoneNumber="5">802742.454 19663023.482 608.269</CgPoint> <CgPoint name="20145" code="LBK" desc="" pointGeometry="point" DTMAttribute="spot" pntSurv="" zoneNumber="5">802742.982000006 19663019.652 606.678</CgPoint> <CgPoint name="20147" code="RBOT" desc="" pointGeometry="point" DTMAttribute="spot" pntSurv="" zoneNumber="5">802743.187 19663018.643 606.144</CgPoint> <CgPoint name="20148" code="RBOT" desc="" pointGeometry="point" DTMAttribute="spot" pntSurv="" zoneNumber="5">802743.344 19663015.945 605.381</CgPoint> <CgPoint name="20149" code="RBOT" desc="" pointGeometry="point" DTMAttribute="spot" pntSurv="" zoneNumber="5">802743.473 19663011.916 605.621</CgPoint> <CgPoint name="20151" code="RBK" desc="" pointGeometry="point" DTMAttribute="spot" pntSurv="" zoneNumber="5">802743.172000003 19663008.703 606.755</CgPoint> <CgPoint name="20152" code="XYZ" desc="" pointGeometry="point" DTMAttribute="determinebyfeature" pntSurv="" zoneNumber="5">802744.306 19663002.708 610.332</CgPoint> <CgPoint name="20153" code="VEGE" desc="GRASS" pointGeometry="point" DTMAttribute="determinebyfeature" pntSurv="" zoneNumber="5">802745.208000001 19662988.246 610.341</CgPoint> <CgPoint name="20154" code="XYZ" desc="" pointGeometry="point" DTMAttribute="determinebyfeature" pntSurv="" zoneNumber="7">802744.467 19662935.721 609.843</CgPoint> <CgPoint name="20141" code="XYZ" desc="" pointGeometry="point" DTMAttribute="determinebyfeature" pntSurv="" zoneNumber="5">802795.565 19663056.181 612.093</CgPoint> <CgPoint name="20140" code="XYZ" desc="" pointGeometry="point" DTMAttribute="determinebyfeature" pntSurv="" zoneNumber="7">802796.163 19663048.532 611.316</CgPoint> <CgPoint name="20139" code="XYZ" desc="" pointGeometry="point" DTMAttribute="determinebyfeature" pntSurv="" zoneNumber="5">802797.245 19663025.508 610.605</CgPoint> <CgPoint name="20138" code="LBK" desc="" pointGeometry="point" DTMAttribute="spot" pntSurv="" zoneNumber="5">802796.274999997 19663019.694 607.598</CgPoint> <CgPoint name="20136" code="RBOT" desc="" pointGeometry="point" DTMAttribute="spot" pntSurv="" zoneNumber="5">802796.386000001 19663018.401 606.161</CgPoint> <CgPoint name="20135" code="RBOT" desc="" pointGeometry="point" DTMAttribute="spot" pntSurv="" zoneNumber="5">802796.109999999 19663016.478 605.218</CgPoint> <CgPoint name="20134" code="RBOT" desc="" pointGeometry="point" DTMAttribute="spot" pntSurv="" zoneNumber="5">802796.382 19663014.055 605.452</CgPoint> <CgPoint name="20132" code="RBK" desc="" pointGeometry="point" DTMAttribute="spot" pntSurv="" zoneNumber="5">802796.959000003 19663012.404 607.751</CgPoint> <CgPoint name="20131" code="XYZ" desc="" pointGeometry="point" DTMAttribute="determinebyfeature" pntSurv="" zoneNumber="5">802797.788 19663004.913 611.285</CgPoint> <CgPoint name="20130" code="XYZ" desc="" pointGeometry="point" DTMAttribute="determinebyfeature" pntSurv="" zoneNumber="7">802797.982 19662981.985 610.821</CgPoint> <CgPoint name="20129" code="XYZ" desc="" pointGeometry="point" DTMAttribute="determinebyfeature" pntSurv="" zoneNumber="7">802797.707 19662959.66 610.321</CgPoint> <CgPoint name="20122" code="XYZ" desc="" pointGeometry="point" DTMAttribute="determinebyfeature" pntSurv="" zoneNumber="5">802845.552 19663053.166 612.919</CgPoint> <CgPoint name="20121" code="XYZ" desc="" pointGeometry="point" DTMAttribute="determinebyfeature" pntSurv="" zoneNumber="5">802844.99 19663035.58 612.303</CgPoint> <CgPoint name="20120" code="LBK" desc="" pointGeometry="point" DTMAttribute="spot" pntSurv="" zoneNumber="5">802846.643999994 19663025.99 607.693</CgPoint> <CgPoint name="20118" code="RBOT" desc="" pointGeometry="point" DTMAttribute="spot" pntSurv="" zoneNumber="5">802846.955 19663024.592 605.482</CgPoint> <CgPoint name="20117" code="RBOT" desc="" pointGeometry="point" DTMAttribute="spot" pntSurv="" zoneNumber="5">802847.378 19663021.754 604.746</CgPoint> <CgPoint name="20116" code="RBOT" desc="" pointGeometry="point" DTMAttribute="spot" pntSurv="" zoneNumber="5">802847.241 19663018.352 605.38</CgPoint> <CgPoint name="20114" code="RBK" desc="" pointGeometry="point" DTMAttribute="spot" pntSurv="" zoneNumber="5">802847.364000018 19663016.904 608.039</CgPoint> <CgPoint name="20113" code="XYZ" desc="" pointGeometry="point" DTMAttribute="determinebyfeature" pntSurv="" zoneNumber="7">802847.048 19663012.112 609.117</CgPoint> <CgPoint name="20112" code="XYZ" desc="" pointGeometry="point" DTMAttribute="determinebyfeature" pntSurv="" zoneNumber="5">802847.077 19663001.76 612.137</CgPoint> <CgPoint name="20111" code="XYZ" desc="" pointGeometry="point" DTMAttribute="determinebyfeature" pntSurv="" zoneNumber="7">802846.589 19662963.64 611.481</CgPoint> <CgPoint name="20110" code="XYZ" desc="" pointGeometry="point" DTMAttribute="determinebyfeature" pntSurv="" zoneNumber="7">802847.254 19662939.033 611.44</CgPoint> <CgPoint name="20095" code="XYZ" desc="" pointGeometry="point" DTMAttribute="determinebyfeature" pntSurv="" zoneNumber="5">802906.378 19663054.757 613.425</CgPoint> <CgPoint name="20096" code="XYZ" desc="" pointGeometry="point" DTMAttribute="determinebyfeature" pntSurv="" zoneNumber="5">802906.349 19663042.413 612.286</CgPoint> <CgPoint name="20097" code="LBK" desc="" pointGeometry="point" DTMAttribute="spot" pntSurv="" zoneNumber="5">802906.044999997 19663038.125 608.187</CgPoint> <CgPoint name="20099" code="RBOT" desc="" pointGeometry="point" DTMAttribute="spot" pntSurv="" zoneNumber="5">802906.299 19663036.06 606.195</CgPoint> <CgPoint name="20100" code="RBOT" desc="" pointGeometry="point" DTMAttribute="spot" pntSurv="" zoneNumber="5">802907.222000001 19663032.86 606.577</CgPoint> <CgPoint name="20101" code="RBOT" desc="" pointGeometry="point" DTMAttribute="spot" pntSurv="" zoneNumber="5">802907.289 19663030.87 606.62</CgPoint> <CgPoint name="20103" code="RBK" desc="" pointGeometry="point" DTMAttribute="spot" pntSurv="" zoneNumber="5">802907.338000009 19663029.951 607.612</CgPoint> <CgPoint name="20104" code="XYZ" desc="" pointGeometry="point" DTMAttribute="determinebyfeature" pntSurv="" zoneNumber="5">802908.65 19663026.492 608.592</CgPoint> <CgPoint name="20105" code="XYZ" desc="" pointGeometry="point" DTMAttribute="determinebyfeature" pntSurv="" zoneNumber="5">802908.752 19663021.398 609.055</CgPoint> <CgPoint name="20106" code="XYZ" desc="" pointGeometry="point" DTMAttribute="determinebyfeature" pntSurv="" zoneNumber="7">802910.389 19663014.896 611.289</CgPoint> <CgPoint name="20107" code="XYZ" desc="" pointGeometry="point" DTMAttribute="determinebyfeature" pntSurv="" zoneNumber="5">802911.166 19663005.102 613.982</CgPoint> <CgPoint name="20108" code="XYZ" desc="" pointGeometry="point" DTMAttribute="determinebyfeature" pntSurv="" zoneNumber="7">802912.949 19662993.352 613.151</CgPoint> <CgPoint name="20109" code="XYZ" desc="" pointGeometry="point" DTMAttribute="determinebyfeature" pntSurv="" zoneNumber="7">802915.637 19662950.945 612.701</CgPoint> <CgPoint name="20094" code="XYZ" desc="" pointGeometry="point" DTMAttribute="determinebyfeature" pntSurv="" zoneNumber="5">802954.426 19663053.603 613.829</CgPoint> <CgPoint name="20093" code="XYZ" desc="" pointGeometry="point" DTMAttribute="determinebyfeature" pntSurv="" zoneNumber="5">802953.913 19663042.106 612.647</CgPoint> <CgPoint name="20092" code="LBK" desc="" pointGeometry="point" DTMAttribute="spot" pntSurv="" zoneNumber="5">802954.579000012 19663033.595 608.206</CgPoint> <CgPoint name="20090" code="RBOT" desc="" pointGeometry="point" DTMAttribute="spot" pntSurv="" zoneNumber="5">802954.795000001 19663032.941 606.577</CgPoint> <CgPoint name="20089" code="RBOT" desc="" pointGeometry="point" DTMAttribute="spot" pntSurv="" zoneNumber="5">802955.65 19663029.939 605.516</CgPoint> <CgPoint name="20088" code="RBOT" desc="" pointGeometry="point" DTMAttribute="spot" pntSurv="" zoneNumber="5">802955.537 19663028.597 606.269</CgPoint> <CgPoint name="20086" code="RBK" desc="" pointGeometry="point" DTMAttribute="spot" pntSurv="" zoneNumber="5">802955.357999997 19663027.21 607.976</CgPoint> <CgPoint name="20085" code="XYZ" desc="" pointGeometry="point" DTMAttribute="determinebyfeature" pntSurv="" zoneNumber="5">802954.240000001 19663016.913 613.781</CgPoint> <CgPoint name="20084" code="XYZ" desc="" pointGeometry="point" DTMAttribute="determinebyfeature" pntSurv="" zoneNumber="7">802954.95 19663006.472 614.04</CgPoint> <CgPoint name="20083" code="XYZ" desc="" pointGeometry="point" DTMAttribute="determinebyfeature" pntSurv="" zoneNumber="7">802954.811 19662985.734 613.652</CgPoint> <CgPoint name="20082" code="XYZ" desc="" pointGeometry="point" DTMAttribute="determinebyfeature" pntSurv="" zoneNumber="7">802954.128 19662966.673 613.584</CgPoint> <CgPoint name="20066" code="XYZ" desc="" pointGeometry="point" DTMAttribute="determinebyfeature" pntSurv="" zoneNumber="7">803034.271 19663051.564 614.904</CgPoint> <CgPoint name="20067" code="XYZ" desc="" pointGeometry="point" DTMAttribute="determinebyfeature" pntSurv="" zoneNumber="5">803033.936999999 19663047.66 612.096</CgPoint> <CgPoint name="20068" code="LBK" desc="" pointGeometry="point" DTMAttribute="spot" pntSurv="" zoneNumber="5">803035.093000006 19663042.118 608</CgPoint> <CgPoint name="20070" code="RBOT" desc="" pointGeometry="point" DTMAttribute="spot" pntSurv="" zoneNumber="5">803034.906000001 19663040.6 606.153</CgPoint> <CgPoint name="20071" code="RBOT" desc="" pointGeometry="point" DTMAttribute="spot" pntSurv="" zoneNumber="5">803034.348000001 19663038.446 606.204</CgPoint> <CgPoint name="20072" code="RBOT" desc="" pointGeometry="point" DTMAttribute="spot" pntSurv="" zoneNumber="5">803034.48 19663036.676 606.811</CgPoint> <CgPoint name="20074" code="RBK" desc="" pointGeometry="point" DTMAttribute="spot" pntSurv="" zoneNumber="5">803034.464999989 19663035.178 607.874</CgPoint> <CgPoint name="20075" code="XYZ" desc="" pointGeometry="point" DTMAttribute="determinebyfeature" pntSurv="" zoneNumber="5">803033.672 19663033.238 608.802</CgPoint> <CgPoint name="20076" code="XYZ" desc="" pointGeometry="point" DTMAttribute="determinebyfeature" pntSurv="" zoneNumber="7">803034.703 19663030.066 609.291</CgPoint> <CgPoint name="20077" code="XYZ" desc="" pointGeometry="point" DTMAttribute="determinebyfeature" pntSurv="" zoneNumber="5">803036.472 19663017.8 614.646</CgPoint> <CgPoint name="20078" code="VEGE" desc="GRASS" pointGeometry="point" DTMAttribute="determinebyfeature" pntSurv="" zoneNumber="5">803037.558 19663012.38 614.926</CgPoint> <CgPoint name="20079" code="XYZ" desc="" pointGeometry="point" DTMAttribute="determinebyfeature" pntSurv="" zoneNumber="7">803037.945 19663005.823 614.766</CgPoint> <CgPoint name="20080" code="XYZ" desc="" pointGeometry="point" DTMAttribute="determinebyfeature" pntSurv="" zoneNumber="7">803039.389 19662981.981 614.558</CgPoint> <CgPoint name="20081" code="XYZ" desc="" pointGeometry="point" DTMAttribute="determinebyfeature" pntSurv="" zoneNumber="7">803035.564000001 19662965.332 614.584</CgPoint> <CgPoint name="20063" code="XYZ" desc="" pointGeometry="point" DTMAttribute="determinebyfeature" pntSurv="" zoneNumber="5">803054.566000001 19663031.041 609.325</CgPoint> <CgPoint name="20062" code="LBK" desc="" pointGeometry="point" DTMAttribute="spot" pntSurv="" zoneNumber="5">803053.023 19663023.35 608.782</CgPoint> <CgPoint name="20060" code="RBOT" desc="" pointGeometry="point" DTMAttribute="spot" pntSurv="" zoneNumber="5">803052.475 19663021.942 608.23</CgPoint> <CgPoint name="20059" code="RBOT" desc="" pointGeometry="point" DTMAttribute="spot" pntSurv="" zoneNumber="5">803051.214000001 19663020.315 608.231</CgPoint> <CgPoint name="20058" code="RBOT" desc="" pointGeometry="point" DTMAttribute="spot" pntSurv="" zoneNumber="5">803050.946000002 19663018.763 608.346</CgPoint> <CgPoint name="20056" code="RBK" desc="" pointGeometry="point" DTMAttribute="spot" pntSurv="" zoneNumber="5">803049.389999999 19663017.129 608.984</CgPoint> <CgPoint name="20055" code="XYZ" desc="" pointGeometry="point" DTMAttribute="determinebyfeature" pntSurv="" zoneNumber="5">803047.612 19663015.681 611.583</CgPoint> <CgPoint name="20054" code="XYZ" desc="" pointGeometry="point" DTMAttribute="determinebyfeature" pntSurv="" zoneNumber="5">803046.237000001 19663010.793 614.836</CgPoint> <CgPoint name="20053" code="XYZ" desc="" pointGeometry="point" DTMAttribute="determinebyfeature" pntSurv="" zoneNumber="7">803051.45 19662960.628 614.258</CgPoint> <CgPoint name="20039" code="XYZ" desc="" pointGeometry="point" DTMAttribute="determinebyfeature" pntSurv="" zoneNumber="5">803054.919 19663040.277 610.706</CgPoint> <CgPoint name="20040" code="XYZ" desc="" pointGeometry="point" DTMAttribute="determinebyfeature" pntSurv="" zoneNumber="5">803059.247 19663036.199 609.908</CgPoint> <CgPoint name="20041" code="XYZ" desc="" pointGeometry="point" DTMAttribute="determinebyfeature" pntSurv="" zoneNumber="5">803066.044 19663029.682 609.528</CgPoint> <CgPoint name="20042" code="LBK" desc="" pointGeometry="point" DTMAttribute="spot" pntSurv="" zoneNumber="5">803067.117000003 19663028.79 608.92</CgPoint> <CgPoint name="20044" code="RBOT" desc="" pointGeometry="point" DTMAttribute="spot" pntSurv="" zoneNumber="5">803068.445 19663027.743 608.007</CgPoint> <CgPoint name="20045" code="RBOT" desc="" pointGeometry="point" DTMAttribute="spot" pntSurv="" zoneNumber="5">803068.033 19663024.925 607.432</CgPoint> <CgPoint name="20046" code="RBOT" desc="" pointGeometry="point" DTMAttribute="spot" pntSurv="" zoneNumber="5">803069.349999999 19663023.717 607.995</CgPoint> <CgPoint name="20048" code="RBK" desc="" pointGeometry="point" DTMAttribute="spot" pntSurv="" zoneNumber="5">803070.546000003 19663022.849 609.025</CgPoint> <CgPoint name="20049" code="XYZ" desc="" pointGeometry="point" DTMAttribute="determinebyfeature" pntSurv="" zoneNumber="5">803074.671000003 19663021.053 613.171</CgPoint> <CgPoint name="20050" code="XYZ" desc="" pointGeometry="point" DTMAttribute="determinebyfeature" pntSurv="" zoneNumber="5">803075.922 19663020.264 614.617</CgPoint> <CgPoint name="20051" code="VEGE" desc="CROP" pointGeometry="point" DTMAttribute="determinebyfeature" pntSurv="" zoneNumber="5">803089.405999999 19663008.929 614.407</CgPoint> <CgPoint name="20052" code="XYZ" desc="" pointGeometry="point" DTMAttribute="determinebyfeature" pntSurv="" zoneNumber="7">803108.767999997 19662991.29 614.357</CgPoint> <CgPoint name="20038" code="XYZ" desc="" pointGeometry="point" DTMAttribute="determinebyfeature" pntSurv="" zoneNumber="7">803047.397000002 19663048.121 614.636</CgPoint> <CgPoint name="20037" code="XYZ" desc="" pointGeometry="point" DTMAttribute="determinebyfeature" pntSurv="" zoneNumber="5">803061.529 19663047.428 613.961</CgPoint> <CgPoint name="20036" code="XYZ" desc="" pointGeometry="point" DTMAttribute="determinebyfeature" pntSurv="" zoneNumber="5">803072.914 19663048.918 610.459</CgPoint> <CgPoint name="20035" code="LBK" desc="" pointGeometry="point" DTMAttribute="spot" pntSurv="" zoneNumber="5">803073.053000003 19663048.848 610.042</CgPoint> <CgPoint name="20033" code="RBOT" desc="" pointGeometry="point" DTMAttribute="spot" pntSurv="" zoneNumber="5">803074.583000003 19663048.76 608.938</CgPoint> <CgPoint name="20032" code="RBOT" desc="" pointGeometry="point" DTMAttribute="spot" pntSurv="" zoneNumber="5">803076.396000006 19663048.735 609.475</CgPoint> <CgPoint name="20031" code="RBOT" desc="" pointGeometry="point" DTMAttribute="spot" pntSurv="" zoneNumber="5">803077.827 19663048.88 609.401</CgPoint> <CgPoint name="20029" code="RBK" desc="" pointGeometry="point" DTMAttribute="spot" pntSurv="" zoneNumber="5">803080.356999991 19663048.471 609.88</CgPoint> <CgPoint name="20028" code="XYZ" desc="" pointGeometry="point" DTMAttribute="determinebyfeature" pntSurv="" zoneNumber="5">803083.789000006 19663047.889 612.471</CgPoint> <CgPoint name="20027" code="XYZ" desc="" pointGeometry="point" DTMAttribute="determinebyfeature" pntSurv="" zoneNumber="7">803097.758 19663046.839 613.415</CgPoint> <CgPoint name="20026" code="XYZ" desc="" pointGeometry="point" DTMAttribute="determinebyfeature" pntSurv="" zoneNumber="7">803117.462000003 19663047.074 614.002</CgPoint> <CgPoint name="20011" code="VEGE" desc="LAWN" pointGeometry="point" DTMAttribute="determinebyfeature" pntSurv="" zoneNumber="5">803035.477000006 19663099.612 615.287</CgPoint> <CgPoint name="20010" code="XYZ" desc="" pointGeometry="point" DTMAttribute="determinebyfeature" pntSurv="" zoneNumber="5">803063.921000003 19663097.27 614.825</CgPoint> <CgPoint name="20009" code="LBK" desc="" pointGeometry="point" DTMAttribute="spot" pntSurv="" zoneNumber="5">803071.354999997 19663095.8 610.611</CgPoint> <CgPoint name="20007" code="RBOT" desc="" pointGeometry="point" DTMAttribute="spot" pntSurv="" zoneNumber="5">803072.509999997 19663097.069 609.451</CgPoint> <CgPoint name="20006" code="RBOT" desc="" pointGeometry="point" DTMAttribute="spot" pntSurv="" zoneNumber="5">803074.519999997 19663096.806 609.375</CgPoint> <CgPoint name="20005" code="RBOT" desc="" pointGeometry="point" DTMAttribute="spot" pntSurv="" zoneNumber="5">803076.688 19663097.083 609.692</CgPoint> <CgPoint name="20003" code="RBK" desc="" pointGeometry="point" DTMAttribute="spot" pntSurv="" zoneNumber="5">803078.523000003 19663096.643 610.319</CgPoint> <CgPoint name="20002" code="XYZ" desc="" pointGeometry="point" DTMAttribute="determinebyfeature" pntSurv="" zoneNumber="5">803086.403999997 19663096.824 613.144</CgPoint> <CgPoint name="20001" code="XYZ" desc="" pointGeometry="point" DTMAttribute="determinebyfeature" pntSurv="" zoneNumber="7">803108.024 19663097.28 614.488</CgPoint> <CgPoint name="20012" code="VEGE" desc="LAWN" pointGeometry="point" DTMAttribute="determinebyfeature" pntSurv="" zoneNumber="5">803002.865000003 19663122.042 613.998</CgPoint> <CgPoint name="20013" code="VEGE" desc="TALLGRASS" pointGeometry="point" DTMAttribute="determinebyfeature" pntSurv="" zoneNumber="5">803039.601000003 19663142.48 614.677</CgPoint> <CgPoint name="20014" code="XYZ" desc="" pointGeometry="point" DTMAttribute="determinebyfeature" pntSurv="" zoneNumber="5">803054.265000003 19663151.471 615.27</CgPoint> <CgPoint name="20015" code="LBK" desc="" pointGeometry="point" DTMAttribute="spot" pntSurv="" zoneNumber="5">803064.350999994 19663158.267 610.753</CgPoint> <CgPoint name="20017" code="RBOT" desc="" pointGeometry="point" DTMAttribute="spot" pntSurv="" zoneNumber="5">803065.510999999 19663159.791 609.076</CgPoint> <CgPoint name="20018" code="RBOT" desc="" pointGeometry="point" DTMAttribute="spot" pntSurv="" zoneNumber="5">803067.796 19663160.874 609.349</CgPoint> <CgPoint name="20019" code="RBOT" desc="" pointGeometry="point" DTMAttribute="spot" pntSurv="" zoneNumber="5">803069.265 19663161.799 609.592</CgPoint> <CgPoint name="20021" code="RBK" desc="" pointGeometry="point" DTMAttribute="spot" pntSurv="" zoneNumber="5">803071.480000009 19663162.112 610.696</CgPoint> <CgPoint name="20022" code="XYZ" desc="" pointGeometry="point" DTMAttribute="determinebyfeature" pntSurv="" zoneNumber="5">803082.070000002 19663170.302 615.233</CgPoint> <CgPoint name="20023" code="VEGE" desc="GRASS" pointGeometry="point" DTMAttribute="determinebyfeature" pntSurv="" zoneNumber="5">803101.778000006 19663180.518 615.253</CgPoint> <CgPoint name="20024" code="VEGE" desc="CROP" pointGeometry="point" DTMAttribute="determinebyfeature" pntSurv="" zoneNumber="5">803112.256999994 19663186.281 615.181</CgPoint> <CgPoint name="20025" code="XYZ" desc="" pointGeometry="point" DTMAttribute="determinebyfeature" pntSurv="" zoneNumber="7">803130.538999997 19663195.714 615.626</CgPoint> </CgPoints> <PlanFeatures> <PlanFeature name="HYDRO010" state="existing" desc="10"> <CoordGeom> <Chain name="HYDRO010" desc="10" code="HYDRO" DTMAttribute="determinebyfeature" pointGeometry="">20142 20143 20144 20145 20147 20148 20149 20151 20152 20153 20154 </Chain> </CoordGeom> </PlanFeature> <PlanFeature name="HYDRO020" state="existing" desc="20"> <CoordGeom> <Chain name="HYDRO020" desc="20" code="HYDRO" DTMAttribute="determinebyfeature" pointGeometry="">20141 20140 20139 20138 20136 20135 20134 20132 20131 20130 20129 </Chain> </CoordGeom> </PlanFeature> <PlanFeature name="HYDRO030" state="existing" desc="30"> <CoordGeom> <Chain name="HYDRO030" desc="30" code="HYDRO" DTMAttribute="determinebyfeature" pointGeometry="">20122 20121 20120 20118 20117 20116 20114 20113 20112 20111 20110 </Chain> </CoordGeom> </PlanFeature> <PlanFeature name="HYDRO040" state="existing" desc="40"> <CoordGeom> <Chain name="HYDRO040" desc="40" code="HYDRO" DTMAttribute="determinebyfeature" pointGeometry="">20095 20096 20097 20099 20100 20101 20103 20104 20105 20106 20107 20108 20109 </Chain> </CoordGeom> </PlanFeature> <PlanFeature name="HYDRO050" state="existing" desc="50"> <CoordGeom> <Chain name="HYDRO050" desc="50" code="HYDRO" DTMAttribute="determinebyfeature" pointGeometry="">20094 20093 20092 20090 20089 20088 20086 20085 20084 20083 20082 </Chain> </CoordGeom> </PlanFeature> <PlanFeature name="HYDRO060" state="existing" desc="60"> <CoordGeom> <Chain name="HYDRO060" desc="60" code="HYDRO" DTMAttribute="determinebyfeature" pointGeometry="">20066 20067 20068 20070 20071 20072 20074 20075 20076 20077 20078 20079 20080 20081 </Chain> </CoordGeom> </PlanFeature> <PlanFeature name="HYDRO070" state="existing" desc="70"> <CoordGeom> <Chain name="HYDRO070" desc="70" code="HYDRO" DTMAttribute="determinebyfeature" pointGeometry="">20063 20062 20060 20059 20058 20056 20055 20054 20053 </Chain> </CoordGeom> </PlanFeature> <PlanFeature name="HYDRO080" state="existing" desc="80"> <CoordGeom> <Chain name="HYDRO080" desc="80" code="HYDRO" DTMAttribute="determinebyfeature" pointGeometry="">20039 20040 20041 20042 20044 20045 20046 20048 20049 20050 20051 20052 </Chain> </CoordGeom> </PlanFeature> <PlanFeature name="HYDRO090" state="existing" desc="90"> <CoordGeom> <Chain name="HYDRO090" desc="90" code="HYDRO" DTMAttribute="determinebyfeature" pointGeometry="">20038 20037 20036 20035 20033 20032 20031 20029 20028 20027 20026 </Chain> </CoordGeom> </PlanFeature> <PlanFeature name="HYDRO100" state="existing" desc="100"> <CoordGeom> <Chain name="HYDRO100" desc="100" code="HYDRO" DTMAttribute="determinebyfeature" pointGeometry="">20011 20010 20009 20007 20006 20005 20003 20002 20001 </Chain> </CoordGeom> </PlanFeature> <PlanFeature name="HYDRO110" state="existing" desc="110"> <CoordGeom> <Chain name="HYDRO110" desc="110" code="HYDRO" DTMAttribute="determinebyfeature" pointGeometry="">20012 20013 20014 20015 20017 20018 20019 20021 20022 20023 20024 20025 </Chain> </CoordGeom> </PlanFeature> </PlanFeatures> <Alignments> <Alignment name="HYDRO010" state="existing" desc="10" staStart="0" length="121.34659962177"> <CoordGeom> <Chain name="HYDRO010" desc="10" code="HYDRO" DTMAttribute="determinebyfeature" pointGeometry="" /> </CoordGeom> <Profile> <ProfAlign name="HYDRO010" desc=""> <PVI>0 611.499</PVI> <PVI>20.9661490259921 609.598</PVI> <PVI>33.3684264346401 608.269</PVI> <PVI>37.2346499214317 606.678</PVI> <PVI>38.2642644180559 606.144</PVI> <PVI>40.9668285660934 605.381</PVI> <PVI>44.9978931926186 605.621</PVI> <PVI>48.2249615174273 606.755</PVI> <PVI>54.3262712994356 610.332</PVI> <PVI>68.8163730256912 610.341</PVI> <PVI>121.34659962177 609.843</PVI> </ProfAlign> </Profile> </Alignment> <Alignment name="HYDRO020" state="existing" desc="20" staStart="0" length="96.8359606254258"> <CoordGeom> <Chain name="HYDRO020" desc="20" code="HYDRO" DTMAttribute="determinebyfeature" pointGeometry="" /> </CoordGeom> <Profile> <ProfAlign name="HYDRO020" desc=""> <PVI>0 612.093</PVI> <PVI>7.6723402633584 611.316</PVI> <PVI>30.7217502380522 610.605</PVI> <PVI>36.6161116075565 607.598</PVI> <PVI>37.9138673644634 606.161</PVI> <PVI>39.8565729600196 605.218</PVI> <PVI>42.2947921840198 605.452</PVI> <PVI>44.0437147019911 607.751</PVI> <PVI>51.5804462260737 611.285</PVI> <PVI>74.5092669576848 610.821</PVI> <PVI>96.8359606254258 610.321</PVI> </ProfAlign> </Profile> </Alignment> <Alignment name="HYDRO030" state="existing" desc="30" staStart="0" length="114.379619878379"> <CoordGeom> <Chain name="HYDRO030" desc="30" code="HYDRO" DTMAttribute="determinebyfeature" pointGeometry="" /> </CoordGeom> <Profile> <ProfAlign name="HYDRO030" desc=""> <PVI>0 612.919</PVI> <PVI>17.5949777028903 612.303</PVI> <PVI>27.3265662594493 607.693</PVI> <PVI>28.7587411822083 605.482</PVI> <PVI>31.6280918050427 604.746</PVI> <PVI>35.0328492070727 605.38</PVI> <PVI>36.4860639307263 608.039</PVI> <PVI>41.2884716606573 609.117</PVI> <PVI>51.6405122751165 612.137</PVI> <PVI>89.7636357578532 611.481</PVI> <PVI>114.379619878379 611.44</PVI> </ProfAlign> </Profile> </Alignment> <Alignment name="HYDRO040" state="existing" desc="40" staStart="0" length="104.666026147083"> <CoordGeom> <Chain name="HYDRO040" desc="40" code="HYDRO" DTMAttribute="determinebyfeature" pointGeometry="" /> </CoordGeom> <Profile> <ProfAlign name="HYDRO040" desc=""> <PVI>0 613.425</PVI> <PVI>12.3440340618677 612.286</PVI> <PVI>16.6427966772223 608.187</PVI> <PVI>18.7233593320922 606.195</PVI> <PVI>22.0538141232364 606.577</PVI> <PVI>24.0449416878611 606.62</PVI> <PVI>24.965247060871 607.612</PVI> <PVI>28.6647098634423 608.592</PVI> <PVI>33.7597309592965 609.055</PVI> <PVI>40.4646375957996 611.289</PVI> <PVI>50.2894106209301 613.982</PVI> <PVI>62.1739210788619 613.151</PVI> <PVI>104.666026147083 612.701</PVI> </ProfAlign> </Profile> </Alignment> <Alignment name="HYDRO050" state="existing" desc="50" staStart="0" length="87.235165494532"> <CoordGeom> <Chain name="HYDRO050" desc="50" code="HYDRO" DTMAttribute="determinebyfeature" pointGeometry="" /> </CoordGeom> <Profile> <ProfAlign name="HYDRO050" desc=""> <PVI>0 613.829</PVI> <PVI>11.5084394189708 612.647</PVI> <PVI>20.0454574552806 608.206</PVI> <PVI>20.734204145968 606.577</PVI> <PVI>23.8555866886211 605.516</PVI> <PVI>25.2023357448989 606.269</PVI> <PVI>26.6008385040122 607.976</PVI> <PVI>36.9583542823476 613.781</PVI> <PVI>47.423466850779 614.04</PVI> <PVI>68.1619326717967 613.652</PVI> <PVI>87.235165494532 613.584</PVI> </ProfAlign> </Profile> </Alignment> <Alignment name="HYDRO060" state="existing" desc="60" staStart="0" length="87.4957434302996"> <CoordGeom> <Chain name="HYDRO060" desc="60" code="HYDRO" DTMAttribute="determinebyfeature" pointGeometry="" /> </CoordGeom> <Profile> <ProfAlign name="HYDRO060" desc=""> <PVI>0 614.904</PVI> <PVI>3.91826135203179 612.096</PVI> <PVI>9.57954211214985 608</PVI> <PVI>11.109016869601 606.153</PVI> <PVI>13.3341191135376 606.204</PVI> <PVI>15.1090343222291 606.811</PVI> <PVI>16.6071094052789 607.874</PVI> <PVI>18.702926440156 608.802</PVI> <PVI>22.038274253685 609.291</PVI> <PVI>34.431180163191 614.646</PVI> <PVI>39.958909894172 614.926</PVI> <PVI>46.5273205123478 614.766</PVI> <PVI>70.4130086960612 614.558</PVI> <PVI>87.4957434302996 614.584</PVI> </ProfAlign> </Profile> </Alignment> <Alignment name="HYDRO070" state="existing" desc="70" staStart="0" length="73.0507857921336"> <CoordGeom> <Chain name="HYDRO070" desc="70" code="HYDRO" DTMAttribute="determinebyfeature" pointGeometry="" /> </CoordGeom> <Profile> <ProfAlign name="HYDRO070" desc=""> <PVI>0 609.325</PVI> <PVI>7.84425459607468 608.782</PVI> <PVI>9.35513777437224 608.23</PVI> <PVI>11.4135959376121 608.231</PVI> <PVI>12.9885651483755 608.346</PVI> <PVI>15.2449099701373 608.984</PVI> <PVI>17.5379402835504 611.583</PVI> <PVI>22.6156532674336 614.836</PVI> <PVI>73.0507857921336 614.258</PVI> </ProfAlign> </Profile> </Alignment> <Alignment name="HYDRO080" state="existing" desc="80" staStart="0" length="74.3477679121796"> <CoordGeom> <Chain name="HYDRO080" desc="80" code="HYDRO" DTMAttribute="determinebyfeature" pointGeometry="" /> </CoordGeom> <Profile> <ProfAlign name="HYDRO080" desc=""> <PVI>0 610.706</PVI> <PVI>5.94656774553031 609.908</PVI> <PVI>15.3630691159594 609.528</PVI> <PVI>16.7584160316887 608.92</PVI> <PVI>18.4495082719684 608.007</PVI> <PVI>21.2974668501132 607.432</PVI> <PVI>23.0845742887352 607.995</PVI> <PVI>24.5623564123424 609.025</PVI> <PVI>29.0613830873478 613.171</PVI> <PVI>30.5404104665804 614.617</PVI> <PVI>48.1557583527234 614.407</PVI> <PVI>74.3477679121796 614.357</PVI> </ProfAlign> </Profile> </Alignment> <Alignment name="HYDRO090" state="existing" desc="90" staStart="0" length="70.3283804524586"> <CoordGeom> <Chain name="HYDRO090" desc="90" code="HYDRO" DTMAttribute="determinebyfeature" pointGeometry="" /> </CoordGeom> <Profile> <ProfAlign name="HYDRO090" desc=""> <PVI>0 614.636</PVI> <PVI>14.1489813398955 613.961</PVI> <PVI>25.6310684762322 610.459</PVI> <PVI>25.7866994495734 610.042</PVI> <PVI>27.3192280787455 608.938</PVI> <PVI>29.1324004406342 609.475</PVI> <PVI>30.5707279350393 609.401</PVI> <PVI>33.1335741998775 609.88</PVI> <PVI>36.6145723423515 612.471</PVI> <PVI>50.6229791339923 613.415</PVI> <PVI>70.3283804524586 614.002</PVI> </ProfAlign> </Profile> </Alignment> <Alignment name="HYDRO100" state="existing" desc="100" staStart="0" length="73.4417794583335"> <CoordGeom> <Chain name="HYDRO100" desc="100" code="HYDRO" DTMAttribute="determinebyfeature" pointGeometry="" /> </CoordGeom> <Profile> <ProfAlign name="HYDRO100" desc=""> <PVI>0 615.287</PVI> <PVI>28.5402540256656 614.825</PVI> <PVI>36.1181993848533 610.611</PVI> <PVI>37.8341207016456 609.451</PVI> <PVI>39.8612538981228 609.375</PVI> <PVI>42.0468780677116 609.692</PVI> <PVI>43.9338929034674 610.319</PVI> <PVI>51.8169711092599 613.144</PVI> <PVI>73.4417794583335 614.488</PVI> </ProfAlign> </Profile> </Alignment> <Alignment name="HYDRO110" state="existing" desc="110" staStart="0" length="147.935587011085"> <CoordGeom> <Chain name="HYDRO110" desc="110" code="HYDRO" DTMAttribute="determinebyfeature" pointGeometry="" /> </CoordGeom> <Profile> <ProfAlign name="HYDRO110" desc=""> <PVI>0 613.998</PVI> <PVI>42.0386196257124 614.677</PVI> <PVI>59.2395201008125 615.27</PVI> <PVI>71.4014694433812 610.753</PVI> <PVI>73.3167177242003 609.076</PVI> <PVI>75.8453762666749 609.349</PVI> <PVI>77.5813445826078 609.592</PVI> <PVI>79.8183501732575 610.696</PVI> <PVI>93.2058144587979 615.233</PVI> <PVI>115.404281075364 615.253</PVI> <PVI>127.363445333388 615.181</PVI> <PVI>147.935587011085 615.626</PVI> </ProfAlign> </Profile> </Alignment> </Alignments> </LandXML>
