I think I may have a case of the Monday's here. I am looking to make an excavation template with two different slopes in InRoads. I want to start from an excavation bottom shape and have the template find the existing surface. The point at which the slope changes in the template is at a set distance below the existing surface. What would be the easiest way to set up this template?
Thanks,Joe
Answer Verified By: Joseph Rusiewicz
