In Geopak SS2 when you describe a profile the SSD is reported with the sag curve and you can use the visibility tool to show a graphical representation based upon a TIN file. Just wondering if there is or will be an equivalent in Open Roads.
Answer Verified By: Sean Keene
Any update on this for ORD? To replace the point sight distance tool in Inroads, I created a template to identify areas obstructed view, but haven't found an openroads replacement for the geopak/inroads sight distance as described above to sample eye/object height along an alignment per a specific increment.
Yes, we need a good way to show line of sight in ORD , because clients want to see this all the time!
Thanks in advance
//Christiaan
Any news on Sight Visibility check for ORD
I ve heard they are working on that and we may expect SSD tools with Update 3. Assumeing Update 2 will be released in November, and since Bentley aiming to relase updates every 3 monith so maybe in February we will have that implemented to ORD. Lack of SSD tools is one of two or three factors for which we are postponing pilot project.
Best,
Adam
OpenRoads Designer 2023 | OpenRail Designer 2023
