When opening a profile view, cross-section view, and or any view that bring ups a X and Y Axis (normally X being stationing and Y being elevation) the Y Axis is defaulting to showing only "ZZZ". I believe this to be caused by the resolution of my monitors. I'm currently using two 29" ACER monitors running at 2560 X 1440. See the image below showcasing the problem. As a side note it seems that some windows also have a tendency to be be "hidden" behind other windows from time to time such as the element selection box, normally this isn't to much of a problem but can be frustrating at times.
The following wiki provides the answer to your question: http://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki/22977.elevation-axis-of-profile-displays-backwards-zzz
Answer Verified By: Cameron Tomkins
