For a 3D model that is built from a 3D Boundary Edges Terrain(ex. intersection) and a Surface Temple with Linear Templates on the edges.
What is the best way to create the bottom mesh?
We can use the 3D break lines generated by the Linear Template. However, when a surface Template is applied to the Terrain there are no 3D lines generated.
So we though we could create a vertical offset terrain to use and append the outside break lines.
Which begs the question in the subject?
Any other suggestions ?
Answer Verified By: Vern Danforth
Vern
OK We found that if you select the surface mesh component and choose properties, that you can Create Linear Features to True. Thank you.
Does any one know how to set this by project... is it a variable or design file setting?
