All of a sudden my project manager is not holding the paths. When I launch PM the correct folder displays with the .prj file but when I click on it it tells me that it cannot located the .gpk file in directory X when it should be in directory Y. When I edit the project manager, the default directory is blank and so are the 3 directories in my cogo preferences. When I select the correct directories and re-launch the .prj it's still looking in the wrong directory and when I again check all the paths in my PM and cogo settings they are blank again. I also noticed its dumping .rsc files in my folders on the network so I deleted those but I still have the same problems. Any idea why it is doing this? Of course things like this only happen during a submittal so any help would be much appreciated.
Answer Verified By: Chuck K.
