I've recently installed the latest version of PowerInroads (845). The application crashes when attempting to open any file (dgn,dwg,dxf,cel,dgnlib,etc). I haven't been able to use the program at all. Bentley tech support recommended I install the latest prerequisite package. I uninstalled PIR, installed prerequisite pack, re-installed PIR. No change, still crashes. The second recommendation from Bentley tech support was to "rebuild my operating system". I'm not going to do that. I'm in the process of installing on other computers here in the office to see if it's localized to my machine, but I figured it might help to ask if anyone has any advice. I've attached the exceptions that are thrown when trying to open the application. All version prior installed and ran just fine.
These are exceptions 2 of 8 thrown when trying to open a file.
Thanks in advance
2015-08-06 Ex 1.txt2015-08-06 Ex 2.txt
I've been trouble shooting this issue with no luck still. I've run debug reports for the 845 version (the one that won't run) and also the 789 version (working fine). I've looked at the two with a text difference viewer and I really don't know what to make of most of it. I've attached those files in case someone else knows what to look for. I also ran Microsoft Debug Diag based on the article found here: http://communities.bentley.com/products/microstation/w/microstation__wiki/16088.microsoft-debugdiag-quick-guide-for-microstation-crash-issues . I've also attached the resulting analysis from that utility. Any help is greatly appreciated.
789msdebug.txt845msdebug.txt
Answer Verified By: Michael-Lane
