Extracting Survey Points Name,N,E,Z,CODE,NOTE
I have survey data of 2 Interstate Highways that cross, with 10 miles of survey data on each leg of the highway, but I only need the survey data for the Interchange only, is there a way to extract survey data with (name, northing, easting, elevation, code, note) still the same. I can do it with the InRoads XML report, but the (name, code, and note) are missing.
