I know I've come across the answer to this question before in a video and I should have noted it in my personal documentation. But now I'm seeing multiple options for locking civil elements and I'm not sure exactly what option to use.
This is what I'm seeing when I right-click my horizontal alignment and go to the rules submenu:
I would expect the first and the last entries above would be mutually exclusively available, so that you would see one or the other, not both at once.
When I right-click on the profile, all I see is "Lock - Deactivate Rule", as locks go.
So what's the distinction between all these options, and when should I use one or the other, and is Remove Rule the only button I really need to avoid?
•Lock - Deactivate Referencing Rules -- When selected, this will turn off any rules on elements which depend on the geometry so when you make a change to the geometry element, it will not automatically process other elements that are dependent on the geometry (i.e. corridors, other ruled geometry, etc.)
•Unlock - Activate Referencing Rules -- This unlocks the geometry references which depend on the geometry element, so any changes to the geometry will update automatically as well as any element which references this geometry.
•Lock - Deactivate Rule -- When you lock the geometry, it will not allow you to make changes or edits to the elements. When selected, the icon will change and only allow you to 'Unlock - Activate Rule'
•Remove Rule -- Deletes the rule from the geometry/element
Generally it is best practice to work with the 'Lock- Deactivate Referencing Rules' because it allows you to make multiple changes without the program processing each time a change is made. Then you can 'Unlock - Activate Reference Rules' and make a change and all the reference rules will process, which will also see all prior changes to the geometry but process only 1 time. The way the rules work is covered in a "Geometry - Best Practices" lecture on the Bentley LEARN Server.
http://learn.bentley.com/app/VideoPlayer/LinkToIndividualCourse?LearningPathID=107181&CourseId=111489&MediaID=5005273
Answer Verified By: Nico Roman
