SS4 OpenRoads - Cross Section Annotation
Using SS4 - Open Roads.  Have been using cross section annotation and was working just fine.  Today nothing is working at all.  Is there something that is may be "looking" for and not finding?  Checked the template in the corridor and it seems fine.  Any suggestions?
  • Have you performed multiple cross section runs in the same dgn file? If you have more than one cross section model in the file, make sure you are annotating the correct model under the "Cross Section Model" drop-down on the upper-left of the Annotate Cross Section dialog box. The dialog defaults to the first model in the file, not the current active model, so you may be annotating a previous run.
