I have cross sections that seem to display multiple slope labels on slopes and garbage text on mainline (see below). from what I am seeing it seems to be only in the super elevated areas, at least in this set of cross sections. I posted something similar in the past and the answer was that I need to make a key station at this point but that does not make sense. If my corridor was set up at 5' template drops and these are at even 50' stations, it should be hitting a template drop.
Chuck,
You should take a look at the triangulated model and make sure it is following the components properly. Looks like you may have some sub surface features getting triangulated. This looks like the issue in the second image, and may explain or solve the extra annotations in the first image.
Mike LongstreetVermont Agency of TransportationCivil Engineering Technical SupportVTCAD Help
