We have a real problem. When bringing in a .fbk file with prism constant and prism height defined, the prism height is being read as 0. Commenting out the Prism Constant allows the rod heights to be read properly, but the distances are now off. This seems to be in all of the SS3 and SS4 versions. I even DL the MR1 of SS4 and I am having the same issues.
JOB "ATX38-68_SELOOP2"UNITS FOOT DMSANGLES RIGHT ZENITHATMOS ONCR ONNEZ 17073 10202021.770 3142813.153 770.708 "60DS"NEZ 17074 10201931.900 3142802.615 771.440 "60DS"TEMP 35.0 CPRESS 987.7 MBARSTN 17073 5.370 "60DS"BS 17074 0PRISM 5.040PRISM CONSTANT -33.0F1 VA 17074 0.00000 90.603 89.46073 "60DS"BS 17074 0F1 VA 17074 0.00000 90.604 89.46066 "60DS"PRISM 5.000PRISM CONSTANT 10.0F1 VA 17075 67.21089 109.650 89.34517 "MISC _W ASPHALT/OHE"F1 VA 17076 36.49119 141.373 89.17375 "MISC _E ASPHALT/OHE"PRISM 5.040PRISM CONSTANT -33.0F1 VA 17077 0.00006 90.600 89.46048 "CK _BS17074"TEMP 35.0 CPRESS 987.4 MBARSTN 17074 5.370 "60DS"BS 17073 0PRISM 5.030PRISM CONSTANT -33.0F1 VA 17073 0.00000 90.606 90.39418 "60DS"PRISM 5.000PRISM CONSTANT 10Deleted 1:56:55 PM 8/28/2015F1 VA 17079 295.29253 112.104 89.56520 "MISC _W ASPHALT/OHE"F1 VA 17078 254.59205 87.665 89.20299 "MISC _E ASPHALT/OHE"PRISM 5.030PRISM CONSTANT -33.0F1 VA 17080 0.00013 90.601 90.39407 "CK _BS17073"
Joe Lukovits
User Since TDP in the 80's,
Vax based Unix Workstations - Interpro32,
from the Intergraph Corp.
I believe this post might help.
https://communities.bentley.com/products/road___site_design/f/geopak-inroads-mx-openroads-forum/110966/fbk-import-to-open-roads-survey-version-ss4/338428#338428
