Is there a way to create custom leader lines for annotating cross sections in Geopak SS3? Currently I am using cells that I created associated with the feature lines built into the template. They display in certain areas instead of the default "X". It works well, however, it has significantly bogged down the process of cutting cross sections and navigating through the model.
Answer Verified By: Shane Albritton
Best,
Adam
OpenRoads Designer 2022 (10.12) | OpenRail Designer 2022 (10.12)
Old topic, but we're also not seeing a reduction in processing time using 904 SS4. On a 3 mile project with many SUDA utilities draped offset from the existing ground with cells, cutting sections every 100' results in over 10 hrs of processing time if it doesn't crash. Was there a specific fix/workflow to improve this?
