When importing a FBK file the distance unit are being converted to meters. How do I correct this issue?
The next capture is post import to SS4:
What are your Design File Working Units?
I use the FDOT seed files. My design file settings are above. I don't see anything there. I really need this resolved so please keep brainstorming!
Thanks.
Cliff
Answer Verified By: cliff
This an example of the 2d traverse routine in geopak. Are you familiar with the command line syntax of classic cogo? The only adjustment available is compass rule. If you are running network or 3d traverse I would run it through Open Roads survey.
Beebe
Has the units issue been resolved?
