Is there a way to copy a superelevation control line/points. For instance I would like to copy the superelevation I created for the Left edge of pavement and have the same superelevation for the shoulder so that I don't have to re-enter all the points and I can just edit the individual stations that I need to.
Neal
As far as copying a existing super lane line as you would like to do, I cannot find anything. Perhaps the developers have a work around. I think the developers are working on improving superelevation....hopefully! Not as easy as it was in SS2.
I have done this for additional entries in SS3 on my super lane lines:
In the superelevation editor, right click on the station entry. Window will pop-up to copy. Then do a right click paste. The entry will populate at the bottom of table. Edit the entry as you like. Exit the editor, select the editor again. The entry should be in numerical order for the super lane line.
HTH,
Joe Lukovits
User Since TDP in the 80's,
Vax based Unix Workstations - Interpro32,
from the Intergraph Corp.
