Is tipically required on Civil engineering plans to show Cut or Fill grafically drawn, they should have a color for Cut and another for Fill, they may be used to representate changes of stratum by asigning a simbol to Clay,Sand or Rock. Normally are in a relation of 1-1(1 full 1 short) 100% of the slope length and another of 50% of the slope length for clay, for other materials may be a symbol like a tadpole.
Link
www.dropbox.com/.../Captura%20de%20pantalla%202015-10-01%2021.28.29.png
Answer Verified By: Nospek Yrenko
Hi, have you gotten any further with this issue. I just moved to Open Roads Designer Connect Edition from InRoads and already miss the "draw slope pattern" tool. Utilizing annotation groups with feature definitions seems to work for drawing (annotating) the slope pattern along the edge of road corridors, however, I need to automatically draw the patterns between regular lines drawn in the 3D view. (ie. not a corridor etc.) It also doesn't seem to work for annotating side slopes generated with the "Create 3D by Slope to target" tool? Anyway, if you have any input, that would be great otherwise Ill keep trying :) Thanks!
Since this an old thread that has already been marked as "answered", you may be better off creating a new thread to ask your questions. Make sure to tell us which version of OpenRoads you are using, because there have been many releases, and they don't all have the same tools (or bugs).
MaryB
