Inroads Roadway Designer Plan View Graphics
Recently, when creating new corridors, the graphics in the plan view of roadway designer are shrinking. The graphic showing the active cross section in plan view varies in size as shown in the photos below. It's becoming an issue when cleaning up end conditions. Anyway to adjust this?
Parents Reply Children
  • There just isn't a 'solution'. I tried everything that i can think of to be able to control the length of that yellow line. (Faking a longer horizontal, faking a longer vertical, using a longer alignment and setting Corridor Station Limits... and so on.) I REALLY wanted to find a way to control this! Basically, if you create a Corridor and Fit the view in Plan, the length of that yellow line becomes about 25% of the length of the total Corridor. And that's just the way it is. As I mentioned earlier, lengthen the Corridor and that line gets longer. The only chance of changing the length of that line (in my opinion) is if one of the savvy programmer dudes on the Roadway Designer has some back-door magic that would affect the length of that line.
    Civilly yours,
    The Zen Dude (also known as "Mark")
    Civil Software Guru & Philosopher
    InRoads User since its birth in the 80's
    OpenRoads Documentation / Training / Support
    Zen Engineering, Owner
