Is it possible to rename curves in Inroads? The default settings assign the names "Curve #1, Curve #2..." but I have multiple, individual, continuous alignments and therefore have multiple curves with the same name (Curve #1, Curve #2...). I'm displaying the curve data on plan and index sheets and would prefer to rename the curves in Inroads instead of using text editor in microstation, as this will help eliminate naming errors. Any help is greatly appreciated.
Answer Verified By: Colin Mucci
This does appear to work, but only partially (in SS2 anyway). It will let you rename the first curve in an alignment, but none of the subsequent curves. Not sure if this glitch is fixed in later versions.
