I have a client who requires cross section to be at scale 1"=5'.
How do I make available / create a 1"=5' scale option?
Where do the standard options reside?
Philip Mashuda
The scales used by the Cross Section tool are the pre-defined Drawing Scales (Settings>Drawing Scale) from MicroStation. The cross section command does not recognize custom scales, so it will be necessary for the user to set the drawing scale after the sheets are cut.
Answer Verified By: Philip Mashuda
