Power GEOPAK 08.11.09.845
I'm trying to draw a line in a 3d model using the DP Station and Offset tool. When I invoke the Line command and then select DP, the status windows says "No Element Found at the Station"
Any suggestions? Is there a better way to draw in a 3d model using a chain and offset?
No luck. Power GEOPAK 08.11.09.845 I've tried: 1. Visualizing the chain. I am in range of the chain. 2. Created a new 3d dgn. 3. Checked to make sure my active level is displayed. 4. Opened a different project (gpk) and tried a different alignment. Same results.5. Tried a different pc. and SS2
I'm not sure what to do at this point. Just to let you know what i'm trying to accomplish. We are replacing a concrete box culvert. i'm trying to draw line work to represent the box in a 3d file to show the excavation of earth. cut and fills in that location. Thanks,
