cut slopes away from existing tin
Does anyone have a procedure to cut or clip a volume from an existing tin using an elevation and going up at a 1:1 slope until it reaches the surface?
(show excavation from surface to a desired elevation at a 1:1 slope)
Then, compare the 2 tins volume difference.
Thanks in advance,
Parents Reply Children
