Does anyone have a procedure to cut or clip a volume from an existing tin using an elevation and going up at a 1:1 slope until it reaches the surface?
(show excavation from surface to a desired elevation at a 1:1 slope)
Then, compare the 2 tins volume difference.
Thanks in advance,
So, I found a solution. First, I didn't understand how to use the build pad.
1.) So, I sketched in a 3d perimeter of the section I wanted to cut away from my existing tin.
2.) I selected the line work and created a terrain model, exported that terrain model to a Geopak tin file.
3.) Merged the new tin and existing tin to get a final tin.
4.) Used the volumes dialogue to calculate the difference in volumes.
Answer Verified By: EL_C_
