Geopak SS2 Xsection sheet creation
MS SS3-08.11.09.655
Geopak SS2 -08.11.09.615
In the past I have always created Cross Section sheets in a separate file from the "stack" of cross sections. Been working fine, until today.
Today I tried to create some new sheets and they looked fine, until I closed the sheet file and reopened it. The referenced xsections had dissapeared.
The references were still listed in the reference box. See below.
In the Reference file box it states that each file is "Write Locked(In Master File). This has never happened before.
But... if I create the sheets in the "Stack" file, the reference files stay as expected. The also have the "Write Locked(In Master File) check mark.
Has anyone seen this behavior before?
Dan
