LNK2001 error
You can ignore/delete this.  I figured out the problem
  • In Help
    Under Using Visual C++ to Create an InRoads Group Macro
    Step Two — VC++ Project Settings
    5. In order to link, make the following changes:
    a.
    Go to the Project > Properties > Linker > Input leaf and set Additional Dependencies to "C:\Program Files (x86)\Bentley\InRoads Group V8.11\sdk\ScadSDK.lib" (and this path is where ever InRoads is installed at!)
    Also, the current version of InRoads is 32 bit, so it may not work if you compile / link as 64 bit.
    Answer Verified By: HDR_Coder
Reply
  • In Help
    a.
