How to edit the drafting notes .dft file
I'm unable to find any information on how to edit the .dft file and what the variables within mean. Any help or direction would be greatly appreciated.
Thank you,
Brian
  • I would like to add some of the computed values I can pull from a xml report in inroads.  specifically delta change in degrees at a particular PI or what the report calls angular difference (end to next).  currently I add sta and northing and easting and that is really helpful but getting delta degree change I have to manually input.  but it is a value I can pull from a report? attached screens shot from the report i find angular difference
Reply
