Corridor Modeling/Key Stations
My corridor is calculating cross sections at points that are neither in my key station list nor on my template drop interval.
Some instances of this appear to be where I HAD a key station drop that I have since deleted but, the corridor still calculates a cross section at that station.
Any suggestions?
Parents Reply Children
  • I don't know if there is a bug with the corridor holding onto Key Stations, but maybe you are about to confirm that. In a non-related area, I know that Corridors started to 'remember' editing done in a transition, so that when changes to templates where made, the transition didn't require re-editing. That 'memory' caused some problems when you really needed or wanted the Corridor to 'forget' that prior edit. There may be something similar going on. I would save the IRD, exit the software, restart and reload the IRD and see if that station section still exists. (And obviously confirming that it doesn't exist in any other aspect of the corridor model.) I've suspected that it might be remembering Key Station entries when I was working on something a few weeks ago, but never confirmed it since I had a lot of other controls going on at the same time, and was adding and removing a number of Key Stations. I put this on my personal list to test some day, but if you confirm that this is true, please post it.
    Civilly yours,
    The Zen Dude (also known as "Mark")
    Civil Software Guru & Philosopher
    InRoads User since its birth in the 80's
    OpenRoads Documentation / Training / Support
    Zen Engineering, Owner
