Hi guys,
I have a problem with changing style for a big number of alignments.
In my Geometry file I have around 100 of horizontals for troughing and 100 for cables lines. Everything with Default style :( I need to display only part of this Geometry horizontals or display everything but in different line's style. Any idea how can I make some filter for alignments?Even if I want to change style I can chose only one at a time not 100...
Agnieszka
Hello Agnieszka!
This is fairly easy.
1) Open your geometry and make sure it's active (below is a picture showing the Styles as Default)
2) Go to Geometry > View Geometry > Horizontal Annotation... On that dialog box, click into the "Include" field under Horizontal Alignments and then go to the Filter. The Filter dialog will allow you to select all of the similar alignments. Click OK when done there and you should see your alignments listed in the Selected window. At the top under Apply Style select Active and also Overwrite. At the bottom of this you can deselect all of the toggles if you really don't need to actually view anything. When you Apply, all of the Selected HA's will have their Styles changed.
Apply this however many times you need to 'bulk' change your Styles to whatever alignments you select.
And like magic ... then Save your geometry.
Answer Verified By: Chris Key
Joe Lukovits
User Since TDP in the 80's,
Vax based Unix Workstations - Interpro32,
from the Intergraph Corp.
