Error when closing a SUDA Model
Every time I close a .dgn that has a SUDA model in it I get the following error and it locks up:
Does anyone know what could be causing this error to occur?
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. ---> System.ApplicationException: AddIn Was Not Set
   at Bentley.Hyd.CP.Application.ApplicationManagerSupervisor.get_SubsurfaceAddIn()
   at Bentley.Hyd.Haestad.Model.Structures.CellCache.StopEvents()
   at Bentley.Hyd.Haestad.Model.Structures.CellCache.OnUnloadedEvent(AddIn sender, UnloadedEventArgs eventArgs)
   --- End of inner exception stack trace ---
   at System.RuntimeMethodHandle._InvokeMethodFast(Object target, Object[] arguments, SignatureStruct& sig, MethodAttributes methodAttributes, RuntimeTypeHandle typeOwner)
   at System.RuntimeMethodHandle.InvokeMethodFast(Object target, Object[] arguments, Signature sig, MethodAttributes methodAttributes, RuntimeTypeHandle typeOwner)
   at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture, Boolean skipVisibilityChecks)
   at System.Delegate.DynamicInvokeImpl(Object[] args)
   at Bentley.Internal.MicroStation.EventHandlerSet.Fire(Object eventKey, Object sender, EventArgs e)
   at Bentley.MicroStation.AddIn.raise_UnloadedEvent(AddIn sender, UnloadedEventArgs eventArgs)
   at Bentley.MicroStation.AddIn.OnUnloaded(UnloadedEventArgs eventArgs)
   at Haestad.Subsurface.SubsurfaceAppLoader.OnUnloaded(UnloadedEventArgs eventArgs)
   at Bentley.MicroStation.AddIn.generateUnloadEvents(Int32 eventType)
   at Bentley.Internal.MicroStation.CoreHook.DispatchNoHandler(UInt32* argStack, UInt32 mysp, IntPtr pFunc)
   at Bentley.Internal.MicroStation.CoreHook.Dispatch(UInt32* argStack, UInt32 mysp, IntPtr pFunc)
************** Loaded Assemblies **************
mscorlib
   Assembly Version: 2.0.0.0
   Win32 Version: 2.0.50727.5485 (Win7SP1GDR.050727-5400)
   CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
Bentley.PowerPlatform.FeatureAspects
   Assembly Version: 1.0.0.0
   Win32 Version: 08.11.09.845
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/Bentley.PowerPlatform.FeatureAspects.DLL
msvcm80
   Assembly Version: 8.0.50727.6195
   Win32 Version: 8.00.50727.6195
   CodeBase: file:///C:/Windows/WinSxS/x86_microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.6195_none_d09154e044272b9a/msvcm80.dll
Bentley.PowerPlatform.FeatureAspects.resources
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/en/Bentley.PowerPlatform.FeatureAspects.resources.DLL
ustation
   Win32 Version: 08.11.09.714
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/ustation.DLL
Bentley.General.1.0
   Win32 Version: 08.33.01.03
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/Assemblies/ECFramework/Bentley.General.1.0.DLL
msvcm90
   Assembly Version: 9.0.30729.6161
   Win32 Version: 9.00.30729.6161
   CodeBase: file:///C:/Windows/WinSxS/x86_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.6161_none_50934f2ebcb7eb57/msvcm90.dll
System
   CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
Bentley.MicroStation.Interfaces.1.0
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/Assemblies/Bentley.MicroStation.Interfaces.1.0.DLL
Bentley.MicroStation.XmlObjectModels
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/Assemblies/Bentley.MicroStation.XmlObjectModels.DLL
System.Xml
   CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
System.Windows.Forms
   Win32 Version: 2.0.50727.5491 (Win7SP1GDR.050727-5400)
   CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
   Win32 Version: 2.0.50727.5492 (Win7SP1GDR.050727-5400)
   CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
Microsoft.ApplicationBlocks.ExceptionManagement.1.0
   Win32 Version: 01.00.00.01
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/Assemblies/Microsoft.ApplicationBlocks.ExceptionManagement.1.0.DLL
Bentley.DialogManager
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/Assemblies/Bentley.DialogManager.DLL
MdlSeed
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/mdlsys/asneeded/MdlSeed.DLL
System.Configuration
   Win32 Version: 2.0.50727.5483 (Win7SP1GDR.050727-5400)
   CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
DetSymbEnabler
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/mdlsys/asneeded/DetSymbEnabler.DLL
Bentley.Designlinks
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/mdlsys/asneeded/Bentley.Designlinks.DLL
Bentley.ECObjects.2.0
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/Assemblies/ECFramework/Bentley.ECObjects.2.0.DLL
Bentley.UI
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/Assemblies/ECFramework/Bentley.UI.DLL
componentset
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/mdlsys/required/componentset.DLL
Bentley.ECSystem.2.0
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/Assemblies/ECFramework/Bentley.ECSystem.2.0.DLL
Bentley.EC.Persistence.2.0
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/Assemblies/ECFramework/Bentley.EC.Persistence.2.0.DLL
Bentley.Platform
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/Assemblies/ECFramework/Bentley.Platform.DLL
Bentley.EC.Controls.2.0
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/Assemblies/ECFramework/Bentley.EC.Controls.2.0.DLL
Bentley.logging-2.0
   Win32 Version: 08.11.04.09
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/Assemblies/ECFramework/Bentley.logging-2.0.DLL
Bentley.Exceptions
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/Assemblies/ECFramework/Bentley.Exceptions.DLL
markup
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/mdlsys/required/markup.DLL
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/Assemblies/Bentley.MicroStation.DLL
Bentley.ECXAttributes
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/Assemblies/Bentley.ECXAttributes.DLL
Bentley.Geometry.Common.1.0
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/Assemblies/ECFramework/Bentley.Geometry.Common.1.0.DLL
mptools
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/mdlsys/required/mptools.DLL
Bentley.DesignlinksHandler
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/mdlsys/required/Bentley.DesignlinksHandler.DLL
Bentley.Civil.Loader.MicroStation.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.Loader.MicroStation.3.1.dll
Bentley.Civil.BCSystem.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.BCSystem.3.1.DLL
Bentley.Civil.CadSystem.Interfaces.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.CadSystem.Interfaces.3.1.DLL
Bentley.Civil.Objects.Presentation.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.Objects.Presentation.3.1.DLL
Bentley.Civil.Objects.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.Objects.3.1.DLL
Bentley.Civil.Geometry.Model.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Model.3.1.DLL
Bentley.Civil.Geometry.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.3.1.DLL
Bentley.Civil.Formatting.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.Formatting.3.1.DLL
Bentley.Civil.Geometry.Microstation.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Microstation.3.1.dll
Bentley.PropertyManager
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/Assemblies/Bentley.PropertyManager.DLL
Bentley.Civil.Geometry.Linear.PropertyEnablers.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Linear.PropertyEnablers.3.1.DLL
Bentley.Civil.Geometry.Linear.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Linear.3.1.DLL
Bentley.Geometry.2.0
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/Assemblies/ECFramework/Bentley.Geometry.2.0.DLL
Bentley.MicroStation.Templates.Support
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/Assemblies/Bentley.MicroStation.Templates.Support.DLL
Bentley.MicroStation.WinForms.ECPropertyPane
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/Assemblies/Bentley.MicroStation.WinForms.ECPropertyPane.DLL
Bentley.MicroStation.MaterialControl
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/Assemblies/Bentley.MicroStation.MaterialControl.DLL
Bentley.MicroStation.WinForms.Controls
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/Assemblies/Bentley.MicroStation.WinForms.Controls.DLL
Bentley.ECObjects.2.0.resources
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/en/Bentley.ECObjects.2.0.resources.DLL
System.Runtime.Serialization
   Assembly Version: 3.0.0.0
   Win32 Version: 3.0.4506.5463 (Win7SP1GDR.030729-5400)
   CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Runtime.Serialization/3.0.0.0__b77a5c561934e089/System.Runtime.Serialization.dll
Bentley.PropertyManager.resources
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/en/Bentley.PropertyManager.resources.DLL
Bentley.ECXAttributesAddIn
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/Assemblies/bentley.ecxattributesaddin.DLL
Microsoft.VisualC
   Assembly Version: 8.0.0.0
   Win32 Version: 8.00.50727.4927
   CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Microsoft.VisualC/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualC.dll
Bentley.Properties.ElementHandlerPropertiesEnabler
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/Assemblies/Bentley.Properties.ElementHandlerPropertiesEnabler.DLL
Bentley.PointCloud
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/Assemblies/Bentley.PointCloud.DLL
bentley.designexplorer
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/Assemblies/bentley.designexplorer.DLL
bentley.designexplorer.elementexplorer
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/Assemblies/bentley.designexplorer.elementexplorer.DLL
Bentley.RasterPropertiesEnabler
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/Assemblies/Bentley.RasterPropertiesEnabler.DLL
Bentley.PointCloud.resources
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/en/Bentley.PointCloud.resources.DLL
Bentley.DesignlinksApp
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/mdlsys/asneeded/Bentley.DesignlinksApp.DLL
Bentley.MicroStation.General
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/Assemblies/Bentley.MicroStation.General.DLL
Bentley.DesignlinksApp.resources
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/en/Bentley.DesignlinksApp.resources.DLL
kmlplacemark
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/mdlsys/asneeded/kmlplacemark.DLL
Bentley.PointCloudAdv
   Assembly Version: 8.11.9.601
   Win32 Version: 08.11.09.601
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Descartes/assemblies/Bentley.PointCloudAdv.dll
Bentley.ExpressionEvaluator
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/Assemblies/bentley.expressionevaluator.DLL
Bentley.DGNECPlugin
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/Assemblies/Bentley.DGNECPlugin.DLL
Bentley.DGNECPlugin.Common
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/Assemblies/Bentley.DGNECPlugin.Common.DLL
Bentley.EC.AbstractUI.2.0
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/Assemblies/ECFramework/Bentley.EC.AbstractUI.2.0.DLL
Bentley.ECUISupport
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/Assemblies/Bentley.ECUISupport.DLL
Bentley.Civil.CadSystem.Microstation.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.CadSystem.Microstation.3.1.dll
Bentley.Civil.Graphics.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.Graphics.3.1.DLL
Bentley.Civil.CadSystem.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.CadSystem.3.1.DLL
Bentley.Windowing
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/Assemblies/ECFramework/Bentley.Windowing.DLL
Bentley.Civil.Model.MSPlugIn.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.Model.MSPlugIn.3.1.dll
Bentley.Civil.Model.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.Model.3.1.DLL
Bentley.Civil.Objects.RuleManagement.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.Objects.RuleManagement.3.1.DLL
Bentley.Civil.Objects.Data.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.Objects.Data.3.1.DLL
Bentley.Civil.MicroStation.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.MicroStation.3.1.DLL
Bentley.Civil.Microstation.Utils.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.Microstation.Utils.3.1.DLL
Bentley.Civil.DTM.3.0
   Win32 Version: 08.11.09.393
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/mdlsys/asneeded/Bentley.Civil.DTM.3.0.DLL
System.Drawing.Design
   CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing.Design/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.Design.dll
Bentley.DTM.Element
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/mdlsys/asneeded/Bentley.DTM.Element.DLL
Bentley.Civil.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.3.1.dll
Bentley.Civil.Applications.GPSTrackExt.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.Applications.GPSTrackExt.3.1.dll
Bentley.Interop.MicroStationDGN
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/Assemblies/Bentley.Interop.MicroStationDGN.DLL
Bentley.GlobalPosition
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/Assemblies/Bentley.GlobalPosition.DLL
Bentley.GeoCoord
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/Assemblies/Bentley.GeoCoord.DLL
Bentley.Civil.Applications.GPSTrackExt.GPSLocalizeSetting.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.Applications.GPSTrackExt.GPSLocalizeSetting.3.1.dll
Bentley.Civil.Applications.Survey.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.Applications.Survey.3.1.dll
Bentley.Civil.Applications.Survey.Objects.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.Applications.Survey.Objects.3.1.DLL
Bentley.Civil.Applications.Survey.COM.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.Applications.Survey.COM.3.1.DLL
Bentley.Civil.UI.Commands.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.UI.Commands.3.1.DLL
Bentley.Civil.UI.Controls.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.UI.Controls.3.1.DLL
Bentley.Civil.Objects.UI.Controls.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.Objects.UI.Controls.3.1.DLL
Bentley.Civil.Geometry.Model.Accessor.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Model.Accessor.3.1.DLL
Bentley.Civil.DomainModel.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.DomainModel.3.1.DLL
Bentley.EC.Presentation.2.0
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/Assemblies/ECFramework/Bentley.EC.Presentation.2.0.DLL
Bentley.Civil.Applications.Survey.Microstation.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.Applications.Survey.Microstation.3.1.DLL
Bentley.Civil.ProjectSettings.Model.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.ProjectSettings.Model.3.1.DLL
Bentley.Civil.UI.Templates.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.UI.Templates.3.1.DLL
Bentley.Civil.Geometry.Model.Commands.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Model.Commands.3.1.DLL
Bentley.Civil.Applications.Survey.Settings.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.Applications.Survey.Settings.3.1.dll
Bentley.Civil.BCSystem.Base.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.BCSystem.Base.3.1.dll
ElementInfo
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/mdlsys/required/ElementInfo.DLL
Bentley.Civil.Commands.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.Commands.3.1.dll
Bentley.Civil.Geometry.Command.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Command.3.1.DLL
Bentley.Civil.Model.UI.ContentManagement.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.Model.UI.ContentManagement.3.1.DLL
Bentley.Civil.GraphicalFilters.Presentation.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.GraphicalFilters.Presentation.3.1.DLL
Bentley.Civil.GraphicalFilters.Model.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.GraphicalFilters.Model.3.1.DLL
Bentley.Civil.DTM.TextImport.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.DTM.TextImport.3.1.DLL
Bentley.Civil.Geometry.Services.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Services.3.1.DLL
Bentley.Civil.DTM.ImportExport.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.DTM.ImportExport.3.1.DLL
Bentley.Civil.ConsensusModel.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.ConsensusModel.3.1.dll
Bentley.ECExchange
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/Assemblies/ECFramework/Bentley.ECExchange.DLL
Bentley.DesignSync.DesignViewer
   Win32 Version: 01.08.01.18
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/DesignSync/Bentley.DesignSync.DesignViewer.dll
Bentley.DesignSync.Interfaces
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/DesignSync/Bentley.DesignSync.Interfaces.DLL
Bentley.DesignSync
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/DesignSync/Bentley.DesignSync.DLL
Bentley.GeometryStructsNET1
   Win32 Version: 08.33.01.04
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/DesignSync/Bentley.GeometryStructsNET1.dll
Bentley.DgnPlatformNET
   Win32 Version: 01.08.01.03
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/DesignSync/Bentley.DgnPlatformNET.dll
Bentley.Civil.ConsensusModel.SDK.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.ConsensusModel.SDK.3.1.dll
Bentley.Civil.ContentManagement.Geopak.2.0
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.ContentManagement.Geopak.2.0.dll
Bentley.Civil.Model.Handlers.ContentManagement.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.Model.Handlers.ContentManagement.3.1.DLL
Bentley.Civil.ContentManagement.MS.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.ContentManagement.MS.3.1.DLL
Bentley.Civil.CoreCommands.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.CoreCommands.3.1.dll
Bentley.Civil.DesignStandards.Presentation.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.DesignStandards.Presentation.3.1.dll
Bentley.Civil.Model.Handlers.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.Model.Handlers.3.1.DLL
Bentley.Civil.DTM.Extension.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.DTM.Extension.3.1.dll
Bentley.Civil.DTM.ImagePP.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.DTM.ImagePP.3.1.dll
Bentley.Civil.DTM.LinearGeometry.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.DTM.LinearGeometry.3.1.dll
Bentley.Civil.DTM.Services.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.DTM.Services.3.1.dll
System.ServiceModel
   CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.ServiceModel/3.0.0.0__b77a5c561934e089/System.ServiceModel.dll
Bentley.Civil.DTM.Services.Civil.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.DTM.Services.Civil.3.1.dll
Bentley.Civil.DTM.Services.NUnit.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.DTM.Services.NUnit.3.1.dll
Bentley.Civil.DTM.TextImportProvider.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.DTM.TextImportProvider.3.1.dll
Bentley.Civil.DTMGraphicalFilters.Model.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.DTMGraphicalFilters.Model.3.1.dll
Bentley.Civil.DTMGraphicalFilters.Presentation.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.DTMGraphicalFilters.Presentation.3.1.dll
Bentley.Civil.EditTM.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.EditTM.3.1.dll
Bentley.Civil.Formatting.Microstation.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.Formatting.Microstation.3.1.dll
Bentley.Civil.Geometry.Coordinates.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Coordinates.3.1.dll
Bentley.Civil.Geometry.DesignStandards.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.DesignStandards.3.1.dll
Bentley.Civil.Geometry.Linear.ComplexConstructions.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Linear.ComplexConstructions.3.1.dll
Bentley.Civil.Geometry.Linear.ComplexConstructions.MSNUnit.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Linear.ComplexConstructions.MSNUnit.3.1.dll
Bentley.Civil.MSNUnit.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.MSNUnit.3.1.DLL
Bentley.Civil.Geometry.Linear.ECXML.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Linear.ECXML.3.1.dll
Bentley.Civil.Geometry.Linear.MSNUnit.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Linear.MSNUnit.3.1.dll
Bentley.Civil.Geometry.Linear.NUnit.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Linear.NUnit.3.1.dll
Bentley.Civil.Geometry.Linear.UnitTestAssistant.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Linear.UnitTestAssistant.3.1.dll
Bentley.Civil.Geometry.MicroStation.MSNUnit.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.MicroStation.MSNUnit.3.1.dll
Bentley.Civil.Model.ContentManagement.Management.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.Model.ContentManagement.Management.3.1.DLL
Bentley.Civil.Geometry.Model.MSNUnit.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Model.MSNUnit.3.1.dll
Bentley.Civil.Geometry.Model.SnapRules.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Model.SnapRules.3.1.dll
Bentley.Civil.Geometry.Presentation.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Presentation.3.1.dll
Bentley.Civil.Model.UI.Geometry.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.Model.UI.Geometry.3.1.DLL
Bentley.Civil.Geometry.Services.Civil.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Services.Civil.3.1.dll
Bentley.Civil.Geometry.Services.GEOPAK.2.0
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Services.GEOPAK.2.0.dll
Bentley.Civil.Geometry.Services.LandXML.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Services.LandXML.3.1.dll
Bentley.Civil.Geometry.VCAdapter.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.VCAdapter.3.1.dll
Bentley.Civil.Geopak.Services.Geometry.2.0
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geopak.Services.Geometry.2.0.dll
Bentley.Civil.Geopak.Services.Geometry.Local.2.0
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geopak.Services.Geometry.Local.2.0.dll
Bentley.Civil.GPSTrackExtCom.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.GPSTrackExtCom.3.1.dll
Bentley.Civil.Help.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.Help.3.1.dll
Bentley.Civil.MessageCenter.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.MessageCenter.3.1.dll
Bentley.Civil.Microstation.TestUtils.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.Microstation.TestUtils.3.1.dll
Bentley.Civil.Model.Tools.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.Model.Tools.3.1.dll
Bentley.Civil.MSNUnit.ECXML.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.MSNUnit.ECXML.3.1.dll
Bentley.Civil.MX.Survey.XINCreator.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.MX.Survey.XINCreator.3.1.dll
Bentley.Civil.Objects.Engine.NUnit.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.Objects.Engine.NUnit.3.1.dll
Bentley.Civil.Objects.Engine.Nunit.Model.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.Objects.Engine.Nunit.Model.3.1.dll
Bentley.Civil.Objects.RuleManagement.Logger.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.Objects.RuleManagement.Logger.3.1.dll
Bentley.Civil.Objects.RuleManagement.NUnit.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.Objects.RuleManagement.NUnit.3.1.dll
Bentley.Civil.Objects.RuleManagement.NUnit.Model.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.Objects.RuleManagement.NUnit.Model.3.1.dll
Bentley.Civil.Objects.Rulemanagement.NUNit.MSPlugIn.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.Objects.Rulemanagement.NUNit.MSPlugIn.3.1.dll
Bentley.Civil.Objects.UI.Coordinates.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.Objects.UI.Coordinates.3.1.dll
Bentley.Civil.Objects.UI.EntryTests.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.Objects.UI.EntryTests.3.1.dll
Bentley.Civil.Preferences.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.Preferences.3.1.dll
Bentley.Civil.ProductDrivers.Geopak.VCAdapter.2.0
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.ProductDrivers.Geopak.VCAdapter.2.0.dll
Bentley.Civil.ProjectSettings.Presentation.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.ProjectSettings.Presentation.3.1.dll
Bentley.Civil.RoadwayDesigner.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.RoadwayDesigner.3.1.dll
Bentley.Civil.Solids.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.Solids.3.1.dll
Bentley.Civil.Solids.PlugIn.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.Solids.PlugIn.3.1.dll
Bentley.Civil.Solids.Plugin.MSNUnit.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.Solids.Plugin.MSNUnit.3.1.dll
Bentley.Civil.Surface.DemToDtm.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.Surface.DemToDtm.3.1.dll
Bentley.Civil.UI.CursorPrompt.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.UI.CursorPrompt.3.1.DLL
Bentley.Civil.UI.ControlBinders.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.UI.ControlBinders.3.1.dll
System.Design
   CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Design/2.0.0.0__b03f5f7f11d50a3a/System.Design.dll
Bentley.Civil.Visualisation.Exporter.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Bentley.Civil.Visualisation.Exporter.3.1.dll
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/RoadwayDesign/bin/plugins/Bentley.Civil.RoadwayDesigner.DLL
Bentley.Civil.Commands.CivilFilter.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/CivilPlatform/Filters/Bentley.Civil.Commands.CivilFilter.3.1.dll
Bentley.Civil.DTM.Services.MX.2.0
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/MX/Bentley.Civil.DTM.Services.MX.2.0.dll
Bentley.Civil.Geometry.Services.MX.2.0
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/MX/Bentley.Civil.Geometry.Services.MX.2.0.dll
Bentley.Civil.MX.ModelFile.2.0
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/MX/Bentley.Civil.MX.ModelFile.2.0.DLL
Bentley.Civil.MX.Interop.MXDrainage
   Assembly Version: 1.7.0.0
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/MX/Bentley.Civil.MX.Interop.MXDrainage.dll
Bentley.Civil.MX.Interop.StdType
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/MX/Bentley.Civil.MX.Interop.StdType.dll
Bentley.Civil.MX.Interop.VBA
   Assembly Version: 6.0.0.0
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/MX/Bentley.Civil.MX.Interop.VBA.dll
Bentley.Civil.MX.StyleSetReader.2.0
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/MX/Bentley.Civil.MX.StyleSetReader.2.0.dll
Bentley.Civil.MX.Surface.2.0
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/MX/Bentley.Civil.MX.Surface.2.0.dll
AxSHDocVw
   Assembly Version: 1.1.0.0
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/Assemblies/ECFramework/AxSHDocVw.DLL
SHDocVw
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/Assemblies/ECFramework/SHDocVw.DLL
Bentley.Bedrock.Redistributable
   Assembly Version: 1.0.3152.28781
   Win32 Version: 1.0.3152.28781
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/Assemblies/Bentley.Bedrock.Redistributable.DLL
System.Web.Services
   CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Web.Services/2.0.0.0__b03f5f7f11d50a3a/System.Web.Services.dll
Bentley.Civil.Geometry.Utilities.ClashDetection
   Assembly Version: 8.11.0.3
   Win32 Version:
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Bentley.Civil.Geometry.Utilities.ClashDetection.dll
Bentley.Civil.Geometry.Utilities.Drawing
   Win32 Version: 8.11.0.3
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Bentley.Civil.Geometry.Utilities.Drawing.DLL
Bentley.Civil.Subsurface
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Bentley.Civil.Subsurface.dll
System.Data
   CodeBase: file:///C:/Windows/assembly/GAC_32/System.Data/2.0.0.0__b77a5c561934e089/System.Data.dll
Bentley.Hyd.CatalogServices
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Bentley.Hyd.CatalogServices.dll
System.Core
   Assembly Version: 3.5.0.0
   Win32 Version: 3.5.30729.5420 built by: Win7SP1
   CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Core/3.5.0.0__b77a5c561934e089/System.Core.dll
Bentley.Hyd.CatalogServices.Model
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Bentley.Hyd.CatalogServices.Model.dll
Bentley.Hyd.CP.Core
   Win32 Version:
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Bentley.Hyd.CP.Core.dll
Haestad.Domain
   Assembly Version: 8.11.5.5
   Win32 Version: 8.11.5.5
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.Domain.DLL
Haestad.Framework
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.Framework.DLL
Haestad.Support
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.Support.DLL
Haestad.Drawing.Domain
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.Drawing.Domain.DLL
Haestad.Mapping
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.Mapping.DLL
Bentley.Hyd.CP
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Bentley.Hyd.CP.dll
Haestad.Drawing.Control
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.Drawing.Control.DLL
Haestad.LicensingFacade
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.LicensingFacade.DLL
Haestad.Framework.Windows.Forms
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.Framework.Windows.Forms.DLL
Haestad.MicroStation.Support.ViewAttributesDialogAddon
   Win32 Version:
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.MicroStation.Support.ViewAttributesDialogAddon.DLL
Bentley.Hyd.Haestad
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Bentley.Hyd.Haestad.dll
Haestad.Domain.StormSewer
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.Domain.StormSewer.DLL
Haestad.StormSewer
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.StormSewer.DLL
Haestad.StormSewerProduct
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.StormSewerProduct.DLL
Haestad.Support.NumericalMethods
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.Support.NumericalMethods.DLL
Bentley.Hyd.Haestad.ProductUpdate
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Bentley.Hyd.Haestad.ProductUpdate.dll
DevExpress.Charts.v9.1.Core
   Assembly Version: 9.1.4.0
   Win32 Version: 9.1.4.0
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/DevExpress.Charts.v9.1.Core.dll
DevExpress.Data.v9.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/DevExpress.Data.v9.1.dll
DevExpress.Utils.v9.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/DevExpress.Utils.v9.1.dll
Accessibility
   CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
DevExpress.XtraBars.v9.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/DevExpress.XtraBars.v9.1.dll
DevExpress.XtraEditors.v9.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/DevExpress.XtraEditors.v9.1.DLL
DevExpress.XtraCharts.v9.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/DevExpress.XtraCharts.v9.1.dll
System.Web
   CodeBase: file:///C:/Windows/assembly/GAC_32/System.Web/2.0.0.0__b03f5f7f11d50a3a/System.Web.dll
DevExpress.XtraNavBar.v9.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/DevExpress.XtraNavBar.v9.1.dll
DevExpress.XtraPivotGrid.v9.1.Core
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/DevExpress.XtraPivotGrid.v9.1.Core.dll
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/DevExpress.XtraPivotGrid.v9.1.dll
DevExpress.XtraPrinting.v9.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/DevExpress.XtraPrinting.v9.1.dll
DevExpress.XtraTreeList.v9.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/DevExpress.XtraTreeList.v9.1.DLL
DevExpress.XtraRichEdit.v9.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/DevExpress.XtraRichEdit.v9.1.DLL
DevExpress.XtraReports.v9.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/DevExpress.XtraReports.v9.1.dll
DevExpress.XtraVerticalGrid.v9.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/DevExpress.XtraVerticalGrid.v9.1.DLL
DWNetworkParser
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/DWNetworkParser.dll
Haestad.Calculations.Dynamic
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.Calculations.Dynamic.dll
Haestad.Hydraulics
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.Hydraulics.DLL
Haestad.Domain.ModelingObjects.Dynamic
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.Domain.ModelingObjects.Dynamic.DLL
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.Domain.ModelingObjects.DLL
Haestad.Calculations.Dynamic.Domain
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.Calculations.Dynamic.Domain.dll
Haestad.Calculations.StormSewer.Domain
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.Calculations.StormSewer.Domain.DLL
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.Calculations.StormSewer.DLL
Haestad.Calculations.Scada.Domain
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.Calculations.Scada.Domain.DLL
Haestad.Calculations.PondPack.OutputReader
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.Calculations.PondPack.OutputReader.DLL
Haestad.Calculations.Scada.ScadaReader
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.Calculations.Scada.ScadaReader.DLL
Haestad.Calculations.GravityDerived
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.Calculations.GravityDerived.dll
Haestad.Calculations.GVFOutputReader
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.Calculations.GVFOutputReader.dll
Haestad.Calculations.StormSewer.OutputReader
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.Calculations.StormSewer.OutputReader.DLL
Haestad.Calculations.GVFSolver
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.Calculations.GVFSolver.dll
Haestad.Calculations.HHSolver.DataObjects
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.Calculations.HHSolver.DataObjects.dll
Haestad.Calculations.HHSolver.DataObjects.VB
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.Calculations.HHSolver.DataObjects.VB.DLL
Microsoft.VisualBasic
   Win32 Version: 8.0.50727.5483 (Win7SP1GDR.050727-5400)
   CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.Calculations.HHSolver.dll
Haestad.Calculations.HydrologyHydraulics
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.Calculations.HydrologyHydraulics.dll
Haestad.Calculations.PondPack.Domain
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.Calculations.PondPack.Domain.DLL
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.Calculations.PondPack.DLL
Haestad.HydrologyHydraulics
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.HydrologyHydraulics.DLL
Haestad.Calculations.Pressure
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.Calculations.Pressure.dll
Haestad.Calculations.Support
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.Calculations.Support.DLL
Haestad.Calculations.Pressure.Domain
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.Calculations.Pressure.Domain.dll
Haestad.Domain.ModelingObjects.Water
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.Domain.ModelingObjects.Water.DLL
Haestad.Calculations.Pressure.FlushingResultsReader
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.Calculations.Pressure.FlushingResultsReader.dll
Haestad.Calculations.Pressure.MSX
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.Calculations.Pressure.MSX.dll
Haestad.Calculations.Pressure.ResultsReader
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.Calculations.Pressure.ResultsReader.dll
Haestad.Calculations.SewerCAD
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.Calculations.SewerCAD.dll
Haestad.Calculations.SewerCAD.Domain
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.Calculations.SewerCAD.Domain.dll
Haestad.Calculations.SWMM5.Domain
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.Calculations.SWMM5.Domain.DLL
Haestad.Calculations.SewerCAD.OutputReader
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.Calculations.SewerCAD.OutputReader.dll
Haestad.Calculations.StormCAD
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.Calculations.StormCAD.dll
Haestad.Calculations.StormCAD.Domain
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.Calculations.StormCAD.Domain.dll
Haestad.Calculations.StormDerivedEngine
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.Calculations.StormDerivedEngine.dll
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.Calculations.SWMM5.dll
Haestad.Calculations.SWMM5.OutputReader
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.Calculations.SWMM5.OutputReader.dll
Haestad.CanvasLibrary.Drivers.GDI
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.CanvasLibrary.Drivers.GDI.dll
Haestad.CanvasLibrary.Framework
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.CanvasLibrary.Framework.DLL
Haestad.CanvasLibrary.Framework.Windows.Forms
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.CanvasLibrary.Framework.Windows.Forms.dll
Haestad.Domain.AceDaoInterop
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.Domain.AceDaoInterop.dll
Haestad.Domain.DaoInterop
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.Domain.DaoInterop.dll
Haestad.Domain.DataExchange
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.Domain.DataExchange.dll
Haestad.Domain.DataExchange.IModel
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.Domain.DataExchange.IModel.dll
Haestad.Domain.DataExchange.IModel.Support
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.Domain.DataExchange.IModel.Support.DLL
Haestad.Domain.DataExchange.IModel.Forms
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.Domain.DataExchange.IModel.Forms.dll
Haestad.Domain.DataExchange.IModelPlugIn
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.Domain.DataExchange.IModelPlugIn.dll
Haestad.Domain.DataObjects
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.Domain.DataObjects.dll
Haestad.Domain.DataObjects.Water
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.Domain.DataObjects.Water.dll
Haestad.Domain.LibraryObjects
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.Domain.LibraryObjects.dll
Haestad.Domain.LibraryObjects.Install
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.Domain.LibraryObjects.Install.dll
System.Configuration.Install
   CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration.Install/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.Install.dll
Haestad.Domain.ModelingObjects.PondPack
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.Domain.ModelingObjects.PondPack.dll
Haestad.Domain.SUE
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.Domain.SUE.dll
Haestad.Drawing
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.Drawing.DLL
Haestad.Framework.Windows.Forms.XtraReports
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.Framework.Windows.Forms.XtraReports.DLL
Haestad.Framework.Windows.Forms.Reporting
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.Framework.Windows.Forms.Reporting.DLL
Haestad.ProjectWiseFacade
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.ProjectWiseFacade.DLL
Haestad.GraphicsLibrary.Support
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.GraphicsLibrary.Support.DLL
Haestad.DrawingStorage
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.DrawingStorage.dll
Haestad.DWNetworkParserBuilder
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.DWNetworkParserBuilder.dll
Haestad.Dynamic.DataExchange.CivilStorm
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.Dynamic.DataExchange.CivilStorm.dll
Haestad.Schema.DataExchange
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.Schema.DataExchange.DLL
Haestad.FileParser
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.FileParser.dll
Haestad.Framework.Windows.Forms.Divil
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.Framework.Windows.Forms.Divil.dll
Haestad.Framework.Windows.Forms.Steema
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.Framework.Windows.Forms.Steema.dll
Haestad.Framework.Windows.Forms.Syncfusion
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.Framework.Windows.Forms.Syncfusion.dll
Haestad.GeoPAK
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.GeoPAK.dll
Haestad.GraphicsFileLibrary.RasterFileLibrary
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.GraphicsFileLibrary.RasterFileLibrary.dll
Haestad.GraphicsFileLibrary.VectorFileLibrary
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.GraphicsFileLibrary.VectorFileLibrary.dll
Haestad.Shapefile
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.Shapefile.DLL
Haestad.GraphicsLibrary.GDI
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.GraphicsLibrary.GDI.dll
Haestad.GraphicsLibrary.GDI.Support
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.GraphicsLibrary.GDI.Support.dll
Haestad.GraphicsLibrary.OpenGL
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.GraphicsLibrary.OpenGL.dll
Haestad.HydraulicReviewer
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.HydraulicReviewer.dll
Haestad.InRoads
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.InRoads.dll
Haestad.LicenseAdministrator.Library
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.LicenseAdministrator.Library.dll
Haestad.LoadBuilder.Calculations
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.LoadBuilder.Calculations.dll
Haestad.LoadBuilder.Calculations.Sewer
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.LoadBuilder.Calculations.Sewer.dll
Haestad.LoadBuilder.Calculations.SewerCAD
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.LoadBuilder.Calculations.SewerCAD.dll
Haestad.LoadBuilder.Calculations.SewerGEMS
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.LoadBuilder.Calculations.SewerGEMS.dll
Haestad.LoadBuilder.Data
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.LoadBuilder.Data.dll
Haestad.LoadBuilder
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.LoadBuilder.dll
Haestad.LoadBuilder.StormSewer
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.LoadBuilder.StormSewer.dll
   Win32 Version:
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.MicroStation.Support.dll
Haestad.ModelBuilder
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.ModelBuilder.dll
Haestad.ModelBuilder.Support
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.ModelBuilder.Support.DLL
Haestad.ModelBuilder.Forms
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.ModelBuilder.Forms.dll
Haestad.MX
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.MX.dll
Haestad.Network
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.Network.dll
Haestad.NetworkBuilder
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.NetworkBuilder.dll
Haestad.SCADA.Domain.Application
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.SCADA.Domain.Application.dll
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.SCADA.Domain.DLL
Haestad.SCADA.Domain.HOPC
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.SCADA.Domain.HOPC.dll
Haestad.SCADA.Domain.OPC
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.SCADA.Domain.OPC.dll
OpcDaNet
   Assembly Version: 9.0.1.0
   Win32 Version: 9.0.1.0
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/OpcDaNet.DLL
Haestad.SCADA.Forms
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.SCADA.Forms.dll
Haestad.ScenarioComparison
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.ScenarioComparison.dll
Haestad.ScenarioComparison.Domain
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.ScenarioComparison.Domain.dll
Haestad.Sewer.DataExchange
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.Sewer.DataExchange.dll
Haestad.Sewer.DataExchange.IModelPlugIn
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.Sewer.DataExchange.IModelPlugIn.dll
Haestad.SQLite
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.SQLite.dll
Haestad.SQLiteConverter.Core
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.SQLiteConverter.Core.dll
Haestad.Storm.DataExchange
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.Storm.DataExchange.dll
Haestad.Water.Forms
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.Water.Forms.DLL
TeeChart
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/TeeChart.DLL
Haestad.StormSewer.SQLiteConverter
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.StormSewer.SQLiteConverter.dll
Haestad.Support.LandXML
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.Support.LandXML.DLL
Haestad.Subsurface
   Assembly Version: 8.11.9.136
   Win32 Version: 8.11.9.136
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.Subsurface.dll
Haestad.SUE.CP.ContentManagement
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.SUE.CP.ContentManagement.dll
Haestad.SUE.CP
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.SUE.CP.dll
Haestad.SUE
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.SUE.DLL
Haestad.SUE.CP.Model.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.SUE.CP.Model.3.1.dll
Haestad.SUE.CP.Presentation
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.SUE.CP.Presentation.dll
SandBar
   Assembly Version: 1.4.3.1
   Win32 Version: 1.4.3.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/SandBar.DLL
Haestad.Support.Mixed
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.Support.Mixed.dll
Haestad.SurfaceModeling.Interop
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.SurfaceModeling.Interop.dll
Haestad.TerrainExtractor
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.TerrainExtractor.dll
Haestad.ThiessenPolygon
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.ThiessenPolygon.dll
Haestad.ThiessenPolygon.Engine
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.ThiessenPolygon.Engine.dll
Haestad.UserDataExtensions
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.UserDataExtensions.dll
Haestad.Water.DataExchange.Controls
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Haestad.Water.DataExchange.Controls.dll
hmimsdascnet
   Assembly Version: 1.0.0.0
   Win32 Version: 1.0.0.0
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/hmimsdascnet.dll
IModelEngineAddIn
   Win32 Version: 08.11.07.63
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/IModelEngineAddIn.dll
Ionic.Zip
   Assembly Version: 1.9.1.8
   Win32 Version: 1.9.1.8
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Ionic.Zip.dll
Microsoft.Data.ConnectionUI.Dialog
   Assembly Version: 0.0.0.0
   Win32 Version: 0.0.0.0
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Microsoft.Data.ConnectionUI.Dialog.dll
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Microsoft.Data.ConnectionUI.DLL
MoreLinq
   Assembly Version: 1.1.17511.0
   Win32 Version: 1.1.17511.618
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/MoreLinq.dll
OpcHDAWrapper
   Win32 Version: 6.0.0.0
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/OpcHDAWrapper.dll
SandDock
   Assembly Version: 3.0.6.1
   Win32 Version: 3.0.6.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/SandDock.dll
TeeChart.Languages
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/TeeChart.Languages.dll
Washington
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Washington.dll
Washington.MicroStation.CP
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Subsurface/Washington.MicroStation.CP.dll
Bentley.MicroStation.Templates
   Win32 Version: 08.11.09.714
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/Assemblies/Bentley.MicroStation.Templates.DLL
Bentley.MicroStation.Templates.Support.resources
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/en/Bentley.MicroStation.Templates.Support.resources.DLL
Bentley.DTM.ElementTemplate
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/Assemblies/Bentley.DTM.ElementTemplate.DLL
Bentley.DTM.Element.resources
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/en/Bentley.DTM.Element.resources.DLL
Bentley.MicroStation.GeoCoord
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/Assemblies/Bentley.MicroStation.GeoCoord.DLL
publishdgn
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/mdlsys/asneeded/publishdgn.DLL
PublishDgn.Interfaces.Transformation
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/mdlsys/asneeded/PublishDgn.Interfaces.Transformation.DLL
bentley.publish
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/mdlsys/asneeded/bentley.publish.DLL
TransformationControls
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/mdlsys/asneeded/TransformationControls.DLL
publishdgn.resources
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/en/publishdgn.resources.DLL
Bentley.RSS
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/Assemblies/Bentley.RSS.DLL
GCSDialog
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/mdlsys/asneeded/GCSDialog.DLL
PrintPrep
   Win32 Version: 08.11.09.615
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PrintPreparation/bin/PrintPrep.dll
Bentley.ExtensionDiscovery
   Win32 Version: 08.33.01.03
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/Assemblies/ECFramework/Bentley.ExtensionDiscovery.DLL
Bentley.MicroStation.ECIntegration
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/Assemblies/BENTLEY.MICROSTATION.ECINTEGRATION.DLL
Bentley.GeorasterECPlugin
   Win32 Version: 08.11.09.104
   CodeBase: file:///C:/PROGRAM%20FILES%20(X86)/BENTLEY/POWERGEOPAK%20V8I%20(SELECTSERIES%204)-SS4/DESCARTES/ASSEMBLIES/BENTLEY.GEORASTERECPLUGIN.dll
Bentley.BaseSQLPlugin
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/Assemblies/ECFramework/extensions/Bentley.BaseSQLPlugin.DLL
Bentley.EC.SQLAdapter
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/Assemblies/ECFramework/extensions/Bentley.EC.SQLAdapter.DLL
Bentley.EC.SchemaMappingSQLBuilder
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/Assemblies/ECFramework/extensions/Bentley.EC.SchemaMappingSQLBuilder.DLL
Bentley.DgnECPlugin3
   Win32 Version: 03.08.01.03
   CodeBase: file:///C:/PROGRAM%20FILES%20(X86)/BENTLEY/POWERGEOPAK%20V8I%20(SELECTSERIES%204)-SS4/POWERGEOPAK/CIVILPLATFORM/DESIGNSYNC/BENTLEY.DGNECPLUGIN3.dll
Bentley.ConfigurableECPlugin
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/Assemblies/ECFramework/extensions/Bentley.ConfigurableECPlugin.DLL
Bentley.Descartes
   Assembly Version: 8.11.9.601
   Win32 Version: 08.11.09.601
   CodeBase: file:///C:/PROGRAM%20FILES%20(X86)/BENTLEY/POWERGEOPAK%20V8I%20(SELECTSERIES%204)-SS4/DESCARTES/ASSEMBLIES/BENTLEY.DESCARTES.dll
Bentley.RasterManager
   Assembly Version: 1.0.0.1
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/Assemblies/Bentley.RasterManager.DLL
Bentley.Civil.Geometry.Services.InRoads.3.1
   Win32 Version: 08.11.09.845
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/RoadwayDesign/bin/Bentley.Civil.Geometry.Services.InRoads.3.1.dll
Bentley.DGNECPlugin.Common.resources
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/en/Bentley.DGNECPlugin.Common.resources.DLL
Bentley.MicroStation.WinForms.Docking
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/Assemblies/Bentley.MicroStation.WinForms.Docking.DLL
Bentley.Civil.LandXml.3.0
   Win32 Version: 08.11.09.394
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/DTMLink/Bentley.Civil.LandXml.3.0.dll
Bentley.ECSystem.2.0.resources
   Assembly Version: 2.0.0.0
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/en/Bentley.ECSystem.2.0.resources.DLL
bentley.designexplorer.resources
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/en/bentley.designexplorer.resources.DLL
Bentley.Windowing.Win32
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/Assemblies/ECFramework/Bentley.Windowing.Win32.DLL
Bentley.Windowing.resources
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/en/Bentley.Windowing.resources.DLL
bentley.designexplorer.elementexplorer.markupsvhandler
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/Assemblies/bentley.designexplorer.elementexplorer.markupsvhandler.DLL
ElementInfo.resources
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/en/ElementInfo.resources.DLL
bentley.designexplorer.elementexplorer.resources
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/en/bentley.designexplorer.elementexplorer.resources.DLL
Bentley.Internal.RealDwg
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/Assemblies/Bentley.Internal.RealDwg.DLL
Bentley.TaskNavigation
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/Assemblies/Bentley.TaskNavigation.DLL
Bentley.TaskNavigation.resources
 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/en/Bentley.TaskNavigation.resources.DLL
Bentley.Geometry.Convert.2.0
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/Assemblies/ECFramework/Bentley.Geometry.Convert.2.0.DLL
Bentley.EC.Controls.2.0.resources
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/en/Bentley.EC.Controls.2.0.resources.DLL
CustomMarshalers
   Win32 Version: 2.0.50727.5483 (Win7SP1GDR.050727-5400)
   CodeBase: file:///C:/Windows/assembly/GAC_32/CustomMarshalers/2.0.0.0__b03f5f7f11d50a3a/CustomMarshalers.dll
Bentley.RSS.Common
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/Assemblies/Bentley.RSS.Common.DLL
Bentley.RasterPropertiesEnabler.resources
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/en/Bentley.RasterPropertiesEnabler.resources.DLL
Bentley.PointCloudAdv.resources
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/Descartes/assemblies/en/Bentley.PointCloudAdv.resources.DLL
Bentley.Units
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/Assemblies/ECFramework/Bentley.Units.DLL
Microsoft.ApplicationBlocks.ExceptionManagement.Interfaces.1.0
   Win32 Version: 01.00.00.02
   CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)-SS4/PowerGEOPAK/Assemblies/Microsoft.ApplicationBlocks.ExceptionManagement.Interfaces.1.0.DLL
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
   <system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
Parents Reply Children
