I have a very simple driveway template with three end conditions (two for a fill situation and one for a cut situation). When using the template on different driveways, sometime the fill EC works, but not on all of them. The most trouble I am having is with the cut section though. I don't think I have seen it work yet on this project. When i say it doesn't work, I mean that EC component isn't drawn at all. I'm not sure what would be the easiest way to troubleshoot this, but I will start with the attached image with a bit of information. Please let me know what other info and what format it would be useful.
Thanks for any help I receive!
(PowerGPK SS2)
Once again, thanks for the reply. I tried to attach the ITL to take a look at. I have run the template test and it functions properly.
Troubleshoot.itl
in the dataset that you sent, I found that if you edit the point "Ditch_F_L_L" and toggle OFF the "Check for Interception" option in End Condition Properties, the cut end conditions will begin solving.
Since the point "Ditch_F_L_L" is the last point of the first end condition, it was failing because the surface was above the hinge point "Agg_1_0_L_L".
In the list of End Condition Rules that we typed up a few years ago, this is #4 on the list. (http://communities.bentley.com/products/road___site_design/b/road_and_site_design_blog/archive/2010/09/16/roadway-designer-end-condition-rules)
Answer Verified By: Ken Harrison
