<?xml version="1.0" encoding="UTF-8" ?>
<?xml-stylesheet type="text/xsl" href="https://communities.bentley.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/"><channel><title>Storm &amp;amp; Sanitary - Pick which face of an inlet a pipe connects to</title><link>https://communities.bentley.com/products/road___site_design/f/geopak-inroads-mx-openroads-forum/113491/storm-sanitary---pick-which-face-of-an-inlet-a-pipe-connects-to</link><description>We use Select Series 2 Storm and Sanitary, sometimes for design and sometimes to generate storm profiles from manually computed structure elevations. On a recent site design I ran into two instances where the pipe I inserted between two structures seems</description><dc:language>en-US</dc:language><generator>Telligent Community 12</generator><item><title>RE: Storm &amp; Sanitary - Pick which face of an inlet a pipe connects to</title><link>https://communities.bentley.com/thread/347274?ContentTypeID=1</link><pubDate>Wed, 18 Nov 2015 10:31:36 GMT</pubDate><guid isPermaLink="false">6dad98f5-dbc9-4c4d-a9ba-e9da8dc6aa8e:1b7456d4-3b09-4a42-b265-413df9e4861b</guid><dc:creator>Marc Bachand</dc:creator><description>There is no way to change this.  I have seen this before and while it does not effect design computations it does look odd in plan view and sheet production.  I think it has something to do with the angle of the pipe entering the structure.  At some point the maximum angle is exceeded and the pipe switches sides.  Maybe try rotating the structure angle slightly.  I assume this would only work if you are very close to that tolerance angle.&lt;br /&gt;
&lt;br /&gt;
Marc&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
