<?xml version="1.0" encoding="UTF-8" ?>
<?xml-stylesheet type="text/xsl" href="https://communities.bentley.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/"><channel><title>Stored graphics alignment not matching actual stationing</title><link>https://communities.bentley.com/products/road___site_design/f/geopak-inroads-mx-openroads-forum/113495/stored-graphics-alignment-not-matching-actual-stationing</link><description>I am creating an alignment within geopak using &amp;quot;store graphics&amp;quot;. However I&amp;#39;ve noticed that while the length of my alignment should be approx 6028&amp;#39;, it&amp;#39;s only coming out to 5980&amp;#39;. It appears that my curves are being stored shorter than what they actually</description><dc:language>en-US</dc:language><generator>Telligent Community 12</generator><item><title>RE: Stored graphics alignment not matching actual stationing</title><link>https://communities.bentley.com/thread/347302?ContentTypeID=1</link><pubDate>Wed, 18 Nov 2015 13:35:09 GMT</pubDate><guid isPermaLink="false">6dad98f5-dbc9-4c4d-a9ba-e9da8dc6aa8e:f3ace23c-7b79-4a25-a253-2bcd80a1c932</guid><dc:creator>Beebe Ray</dc:creator><description>It sounds as if you have stored your alignment with the Chord Definition turned on in the Store Graphics dialog.  If you open the dialog and go to Settings Pull Down menu and you see a check next to Chord Definition then you have stored all  your curves as Chord Defined Curves.  Unless this is a rail project you may want to turn that off and restore the chain with circular defined curves which is the default.&lt;br /&gt;
&lt;br /&gt;
Other things to check are the Design File Advanced working units to make sure they are set correctly.&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
