<?xml version="1.0" encoding="UTF-8" ?>
<?xml-stylesheet type="text/xsl" href="https://communities.bentley.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/"><channel><title>Working with SUE - Unable to manipulate elements after placing them</title><link>https://communities.bentley.com/products/road___site_design/f/geopak-inroads-mx-openroads-forum/113630/working-with-sue---unable-to-manipulate-elements-after-placing-them</link><description>Hi,
 I am trying convert our 2D background information into a 3D SUE model and then as I receive the daylighting results adjust my model.
 I am able to use the extract utilities from graphics tool to generate the original model. From what I have seen</description><dc:language>en-US</dc:language><generator>Telligent Community 12</generator><item><title>RE: Working with SUE - Unable to manipulate elements after placing them</title><link>https://communities.bentley.com/thread/347669?ContentTypeID=1</link><pubDate>Fri, 20 Nov 2015 16:50:43 GMT</pubDate><guid isPermaLink="false">6dad98f5-dbc9-4c4d-a9ba-e9da8dc6aa8e:1f8e433a-a513-461f-9e99-4831267dc6e2</guid><dc:creator>Robert Garrett</dc:creator><description>&lt;p&gt;Hi Lindsey: The ways that a feature can be manipulated will vary depending on how the feature is created. For example, when you say you create two nodes and a conduit between them, the rules used to define the conduit are best described as &amp;quot;conduit between two nodes&amp;quot;. Thus you can redefine the conduit by changing the end nodes, or you can insert bends (from the context toolbox).&lt;br /&gt; &lt;br /&gt; For extracted graphics the rule conduit is defined by its source graphic.&lt;br /&gt; &lt;br /&gt; For the profiles, these also can vary depending on how it was originally modeled.&lt;br /&gt; &lt;br /&gt; If you can provide a sample of what you have and the needed manipulation then I can better describe how to accomplish the desired result.&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
