I am using Power InRoads SS2. For one of my project I need to show the final cut and fill quantities between proposed and existing surfaces. Initially, I am given ex. surface area about 100,000 sq meters. The proposed surface will be created from scratch based on the hand drawn sketch which will have few points with proposed coordinates and elevations. At the end, I’ll have to produce a quantity report of cut and fill.
I’ve tried to use isopach surface to resolve this issue however I could not find a solution. Isopach surface either displays grid or contours elev. differences between prop. and ex. surfaces. Is there a way to generate report of cut and fill quantities for specific area.
Thanks.
Artem
Answer Verified By: Artem Bentsel
