Exporting 2D model to DWG no width - MX SS4
When I export a MX model to DWG, I get 2 files. One is the 3D model. The other is a 2D model. The problem is that the 2D model contains 3D polylines with no elevation. A 3d polyline cannot contain a width. Therefore it should be converted to 2D polylines.
It is possible to set the planar line strings to polylines instead of 3D polylines in the options dialogbox. No matter wat setting it is, the export keeps containing 3D polylines. It can be solved in AutoCAD by using a lisproutine, but it is a setting in MX/MS that should be working. (in SS3 it worked...)
With regards
Gunther Groenestein
