I am benching from the top down. The side slope seeks intersection 2 feet below grade and then back up to grade. Then I need to bench from the top down and intersect the line 'Bench Target'. Can an end condition target another component in the template? Any examples to share?
I need to create a component volume for the area between the side slope and the benching. Can the overlay components be made to follow the benching?
I can do this with display rules and many benches of different heights or in two parts. The first is to run the basic side slope template and the use a linear template to do benching. I would like to have a single template that achieves the goal.
Paul
Hey! That looks familiar!
Module 4 at this link describes the use of Mark's template. As he says, it was designed for SS2, but the same premise applies in all subsequent versions of InRoads/OpenRoads.
www.oregon.gov/.../InRoads-Training.aspx
You BETTER recognize that Ray!!! ; )
