It's has been a few years since I have processed an input file from an outside source. This particular input file is for a Geopak Alignment. It appears as if they just did a chain describe and saved it as an output file. Below is a copy of the file. I have renamed the file with the correct GPK and the extension with the correct format (user and input). When I load the input file and read it, it comes back with syntax errors on every line. This leads me to believe that I missed a step with the file for it to be read correctly or I need to tell my source that they have to do something different. Any help would be greatly appreciated. (Using Microstation SS3 with Geopak SS2)
Mark
Copyright: (c) 2013 Bentley Systems, Incorporated. All rights reserved. Project: s350219 Subject: Job No. 19 Operator: TJ Date: Monday November 16, 2015 3:10 pm * 1 DESCRIBE CHAIN INPTH11 Chain INPTH11 contains: TJ2222 CUR TJ2225 TJ2275 TJ2288 CUR TJ2300 Beginning chain INPTH11 description=============================================================================== Point TJ2222 X 407,589.601 Y 110,967.915 Sta 885+00.000 Course from TJ2222 to PC TJ2225 51° 25' 16.694" Dist 1,442.024 Curve Data *----------*Curve TJ2225 P.I. Station 902+80.057 X 408,981.165 Y 112,077.939Delta = 6° 45' 10.151" (RT)Degree = 1° 00' 00.000"Tangent = 338.032Length = 675.282Radius = 5,729.578External = 9.963Long Chord = 674.891Mid. Ord. = 9.946P.C. Station 899+42.024 X 408,716.907 Y 111,867.146P.T. Station 906+17.306 X 409,268.376 Y 112,256.197C.C. X 412,289.809 Y 107,388.034Back = 51° 25' 16.694" Ahead = 58° 10' 26.845" Chord Bear = 54° 47' 51.769" End Region 1Equation: Sta 906+17.306 (BK) = Sta 905+38.210 (AH) ---------------- Begin Region 2 Point TJ2275 X 409,268.376 Y 112,256.197 Sta 905+38.210 Course from TJ2275 to TJ2288 58° 10' 26.845" Dist 896.791 End Region 2Equation: Sta 914+35.001 (BK) = Sta 930+39.400 (AH) ---------------- Begin Region 3 Point TJ2288 X 410,030.338 Y 112,729.110 Sta 930+39.400 Course from TJ2288 to PC TJ2300 58° 10' 26.844" Dist 197.197 Curve Data *----------*Curve TJ2300 P.I. Station 933+95.837 X 410,333.187 Y 112,917.074Delta = 25° 04' 14.337" (LT)Degree = 8° 00' 00.000"Tangent = 159.240Length = 313.383Radius = 716.197External = 17.489Long Chord = 310.889Mid. Ord. = 17.072P.C. Station 932+36.597 X 410,197.887 Y 112,833.100P.T. Station 935+49.980 X 410,420.156 Y 113,050.467C.C. X 409,820.208 Y 113,441.620Back = 58° 10' 26.844" Ahead = 33° 06' 12.508" Chord Bear = 45° 38' 19.676" ===============================================================================Ending chain INPTH11 description
