This error I get when I try to open InRoads.
Microsoft.Net Framework Unhandled exception has occurred in a component in your application. If you
click Continue, the application will ignore this error and attempt to continue.
Unable to load one or more of the requested types.
Retrieve the LoaderExeptions property for more information.
We just had a visit form Bentley for microstation updates. My config file was changed so that whenever I
click on any of the three desktop micorstation icons, Bentley Map
Enterprise, InRoads survey, or Micorstation V8i, all are opened at the same
time. I am hoping that this is what is causing the error. What I need to
happen is to edit the config file so that I only open microstation or
InRoads or Bentley Map. I realize that both InRoads and Bentley Map run
on top of Microstaton. Most of the time I only need to use Microstation V8i,
without InRoads or Map. I need InRoads to process field survey data, and Map for sending and receiving .shp file data.
I just need to know how to fix the config file to change how each is opened.
If I click on the desktop icon for InRoads Survey, I will also get this error:
MDL Loader: Could not load appsication Bentley.Inroads.Commands.AT.dll
InRoads will open but not function well.
Any help would be appreciated.
Ken B
Kenneth.b.burns3.ctr@mail.mil
InRoads survey: 08.11.09.845
MicroStation: 08.11.09.714
Bentley Map: 08.11.09.615
Answer Verified By: Jacquelyn Pettus
